Question about Dryers
Alarm light on my hoover dyc 8913b - Dryers
Could you tell me where the thermal limiter is situated in a DYC8913B please
Ian, Did not find your particular model, links below may help in changing and testing your thermostat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Condenser Dryer Model No DYC 8913B Product Code 31100391
Hoover DYC8913B 80 Thermal Limiter
Dryer Isnt Heating High Limit Thermostat Testing Dryer Troubleshooting...
How to replace thermostat on tumble dryer how to diagnose the fault
Apr 24, 2016 | Hoover Dryers
Why is my Hoover A Class upright freezer alarm light constantly on
1) It could be a short. 2) The thermo sensor that turns the light on could be defective and needs to be replaced.
Mar 24, 2015 | Hoover 9.9 cu. ft. / 280 liter Upright...
Hoover Manuals
call the closest Hoover warranty center
Oct 19, 2013 | Vacuums
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
Wat does the malfunction light mean is it sereous
There are currently over 600 possible "generic" OBD Diagostic Test Codes (DTCs - also known as "fault codes") and several hundred "manufacturer-specific" DTCs that are possible causes of the malfunction indicator light to come on.
Some of the possible causes are not very serious. Others can cause severe damage to your car if you continue to operate it without correcting the cause of the DTC.
In short, you must scan your onboard computer network to retrieve the DTCs that have caused the light to come on. Until this is done and you have the DYC numbers available, NOBODY can tell you if this particular problem is serious or not.
Please also review the following article:
Why Is My Engine Light On?
Apr 11, 2012 | 2005 Hyundai Getz 1.1
Hoover freezer alarm light on ,if i turn freezer off for 10 mins it goes out but comes back on later.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Oct 15, 2009 | Hoover HCA390FFK Bottom Freezer...
My freezer is freezing at the bottom but is not at
Short on refrigerant would be a good starting point, pressure temp relationship should be tested by an opperative.
Jun 27, 2009 | Hoover 9.9 cu. ft. / 280 liter Upright...
FROST AND ALARM LIGHT ON
Your defrost timer, switch or circuit board is probably shot or it would be defrosting.
Use a fridge / freezer thermometer to tell if temperture high (it should be 0 F plus or minus 5 degrees) to determine if it is too high - this is normal if frost builds up but will get worse unless repaired.
May 04, 2009 | Hoover Freezers
Dryers Logo
138 people viewed this question
Top Dryers Experts
