Question about Jawbone Big Jambox Portable Bluetooth Speaker - Graphite Hex
Fix jam box pair button
Second jam box and pairing button has become stuck inside unit and now unable to pair to anything. Any help on a fix to this issue? Thanks in advance-
After I paired my Jam wireless hx-p230f to my Samsung Galaxy J-1,I rcvd a mssg to use jam Smart Lock. When I tried to look up /find infocould not find anything. can you explain to me what this is?
Follow the instructions of your device to pair the unit. ... Por manual de instrucciones e Package Contents informaci?n de garant?a en espa?ol vis?tenos en www.hmdxaudio.com Thank you for spreading the Jam and purchasing the HMDX JAM Classic
Sep 08, 2016 | Samsung Office Equipment & Supplies
I am unable to install Bluetooth as I have no phone setting on the car , can you help
How to Fix Bluetooth Pairing Problems - Techlicious
www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
Dec 29, 2015 - First, go into your phone's settings and tap on Bluetooth; doing so makes the .... If it is similar to my HP printer, there is a "Wireless Setup Wizard" in the .... I am not able to get my contacts to pair with my vehicle's bluetooth, .... Lately Ihave been unable to pair it with my laptop (Dell Vostro running Win7 64 bit).
Get help connecting your iPhone, iPad, or iPod touch with ...
https://support.apple.com/en-us/HT203412
AppleNov 7, 2015 - If you can't pair or connect your iOS device with your car stereo, or you ... You can connect your iOS device with a compatible car stereo using CarPlay,Bluetooth, or a USB cable. ... On your iPhone, go to Settings > General > Siri and make sure that Siri ... Install any firmware updates for your CarPlay stereo.
Using Bluetooth - Motorola Support
Jan 10, 2016 | Cell Phones
Jambox
The same thing it's happened when my jam box won't turn off because the Power Button has sunken in!? Someone help!
Aug 28, 2014 | Jawbone Big Jambox Portable Bluetooth...
How to fix a flashing green light xbox 360 controller
You have the controller set in "pairing mode." This enables the controller to be paired with the X-Box. Either press the sync button on the X-Box to pair it, or take the batteries out of the controller to clear it.
Dec 14, 2013 | Microsoft MS Xbox 360 Common Controller...
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
Paper jams too often and for no apparent reason. This time tore paper and therefore unable to unjam!
To clear the paper jams always follow the instructions from the manufacturer, here is the support page from Brother website.
Also, sometimes when I get paper torn inside, I use a pair of long-nose pliers to remove it, but be careful not to damage any parts inside the printer.
If the printer is jamming constantly then that means you have a hardware issue in there. Look carefully where is usually jamming and see if you have a clip that stops the paper or a roller that's not pulling the paper and try to fix it or replace the faulty part.
Dec 02, 2010 | Brother HL-2040 Laser Printer
How do I restore factory settings on my BlueAnt ST3. I have a new Blackberry and every time I try to pair them the Blackberry comes up with 'Unable to pair with BlueAnt ST3. Try again?' and every time I...
Here is how I got my Samsung to pair (on page 12 of the Blue ant manual):
Deleting all Paired Devices & Phonebook entries:
1. Ensure the SUPERTOOTH 3 is switched OFF, press
& hold the Volume Up (8) Button.
2. Whilst holding down the Volume Up (8) Button, press
the MFB (1) for 1 second or until a distinctive melody
is heard through the speaker, the software version will
then be announced. Once this occurs, please switch the
SUPERTOOTH 3 off for a minimum of 10 seconds.
All paired devices & phonebook entries have now
been erased.
Go back in and pair your phone, use pass code 0000 and let it reload your address book and you should be good to go
Sep 29, 2010 | Computers & Internet
How to connect SAMSUNG bluetooth headset SBH 650 to my Nokia e71
When the pairing process between the E71 and SBH650 starts, try immediately to hold down, or press every half a second, the central 'call' button on the SBH650 - to force the SBH650 to think it is pairing with a new device. It took me 5-10 min of playing about in a similar situation, but eventually the SBH650 cleared it's 'memory' and the '0000' pairing code worked with another telephone...
however, I have never managed to pair the SBH650 with OS 3.0 upgraded ipod touch 2nd gen.
May 13, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
2000 Toyota Corolla VE -- Glove Box Stuck
The most common cause is something inside the glove box jammed in the latch. Push glove box door release , and GENTLY insert a flat putty knife, plastic knife, or similar type tool in the groove of door, GENTLY try to pry open the door. U will probably (hopefully) find a napkin, map, or glove (does anybody actually put gloves in the glove box?) jammed in the inside latch. Let me know how u make out.
Nov 02, 2008 | 2000 Toyota Corolla
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Apr 19, 2008 | Radio Communications
Jawbone Big Jambox Portable Bluetooth Speaker - Graphite Hex Logo
149 people viewed this question
Top Jawbone Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jawbone Audio Player and Recorder Expert? Answer questions, earn points and help others
