Question about Fellowes Powershred 2127S Shredder Strip Cut 3440501
Have a Fellowes 2127S, bin full light stays on when trying to shred, where are the bin full sensor so i can clean them?s
And what does a sensor look like?
fellowesrep
  • 102 Answers
SOURCE: shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Posted on Feb 26, 2008
  • 105 Answers
SOURCE: The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Posted on May 14, 2009
SOURCE: Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Posted on Jul 07, 2009
haystack11
  • 55 Answers
SOURCE: we have a Fellowes Powershred C-220C and the
Only if you are mechanically handy and know how to take a part. Most of these shredder's sensors are PLASTIC and break EASILY. I should know, I had to take apart my wife's shredder.
I had to bypass the sensor and rewire it. It can be done if you know what you are doing. If not, don't try it
In your case I would unscrew the top assembly. Than I would use a can of canned air to clean out the sensor eye. Than I would use tweezers to pull out all specks of paper I could find.
Your best bet is to try to return it for a replacement.
Posted on Sep 24, 2009
Testimonial: "Thanks! I will see if our janitor can fix it Bev"
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
Nov 11, 2009 | Fellowes DM15C Shredder
Will not shred, but will go in reverse
Sorry don't mean to point out something obvious, but are you being shown any indication lights that the waste basket is not seated correctly in the bin or the head? If not, then you may want to try and check these connections anyway. Lights can burn out.
Aug 22, 2009 | Fellowes PS60-2 Shredder
Model C-480C, always says bin is full! Where is the sensor?
Look up under the cutter asm and remove the paper shreds that are stuck in the blade assembly.Also clean the sensors with air or cotton swab.
Jun 03, 2009 | Fellowes Manufacturing C420 (Strip-Cut)...
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Mar 26, 2009 | Fellowes Office Equipment & Supplies
Fellowes S8-*5c
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Shredder problems
Dec 07, 2007 | Fellowes Powershred 420 Shredder
Fellowes Powershred 2127S Shredder Strip Cut 3440501 Logo
71 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
