Question about liftmaster Home Security
HORMANN GARAGE DOOR WOT WORK A435
CUTS OUT HALFWAY HAS LED FLASH CODES
2 Suggested Answers
  • 3197 Answers
SOURCE: garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Posted on Jul 07, 2010
I replace new battery for my nikon coolpix p600 but still can not switch on. Please tell me how to fix this problem...thanks Larry
You will have to tell us what happens when you put a EN-EL23 battery inside the camera and you hook it up to the charger or USB. If the charger or USB is hooked up the Camera will Turn ON. The POWER LED will be GREEN. Another LED on the camera will FLASH GREEN. If this happens when you charge it you are halfway home. Change it until the flashing LED turns off. This means Battery is FULLY changed. Then REMOVE the USB or CHARGER and try to turn it on.
Jan 18, 2017 | Nikon COOLPIX P6000 Digital Camera
Cannot program new garage code
You are missing a step. It sounds like you have a genie intellicode black wireless keyless entry unit. The final step is to program to the opener. When you open halfway and press the prog and 8 keys, youve unlearned the unit from the opener. Lets start over. Complete the previous steps and then finally, press the code or learn button on the opener. There is a red LED light next to it which will flash after pressing it. Within 30 seconds, type your new code and press the up/down or enter button on the keypad. Then press the up/down or enter button a second time. Programming is complete!
Apr 22, 2014 | Building Materials
Hormann garage door
If the courtesy lights on the motor unit aren't turning on, there may be no power getting to the machine, or there may be a fault in the control board. If the opener is getting mains power, I would suggest calling a Hormann dealer.
Sep 17, 2013 | Building Materials
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
How do I reset hand held door opener for horman silent drive 5500 series
The instructions for programming are on page 34 of your owners manual. If you do not have the manual you can go here.
http://www.hormann.us/assets/1/Page/SilentDrive_TR10H004D_0710.pdf
May 12, 2012 | Sears Craftsman LiftMaster Chamberlain...
List of code error for honda accord sm4
If your 1989 Accord has an EFI engine, then your PGM computer (under the passenger floor carpet) will flash fault codes, through the LED light on the computer.
For self-diagnostic procedure, turn the key to ON and observe the LED flash sequence.
The following table shows the early LED type codes:
Nov 01, 2011 | 1989 Honda Accord 4 Door
The bluetooth head set wont turn on how do i turn it on?
Press the K1 button, the one next to the M of MAD CATZ and hold it down for 8, yes Eight seconds.
It should beep twice and the blue LED will flash.
The manual is here just past halfway down the list.
www.madcatz.com/Default.asp?Page=43
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
Home Security Logo
70 people viewed this question
Top liftmaster Home Security Experts
Lawrence Oravetz
Jean DeLauche
Jean DeLauche
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
