Question about Neff U1721 Double circotherm Electric Oven
Neff oven element glows white
I replaced the element yesterday and now when the oven is turn on. It gets hot and glows white. Any ideas??
    Genius:
  • 1,669 Answers
It sounds like the wrong replacement element for the power it is getting. If you are using a 220Volt stove, the element MUST be for that voltage and NOT for 110 Volts.
Posted on Jan 23, 2013
  • 1462 Answers
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Posted on Apr 16, 2007
barkencoa
  • 3463 Answers
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Element or thermostat - Neff U1721 cooker
Hi there.
It is possible that the element in your oven is faulty again without there being any external evidence that it is so..
To be certain whether it is faulty or not , you really need to test it with a meter,preferably an anologue one with a audible beep to test for continuity.
What you need to do is disconnect the element, and with the meter probes touch the terminals of the element, if it is o/k then the meter will beep, no beep ,element open circuit.
If your meter does not have a beeper, then set it the ohms range, and again test across the element terminals, if it is o/k then the pointer will deflect all the way across, no deflection, element
faulty.
It is doubtful that it will be a faulty thermostat,if the temp indicator light shows, that shows the supply is getting to the element.
If no light , then yes, it could be stat, to test if it is working, switch oven on, and with the element reconnected, test for voltage with the meter set on 240 volt range,no reading, stat faulty or no power between stat and element.
This should help you sort out what has happened.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
barkencoa
  • 3463 Answers
SOURCE: replacing the element in a NEFF U1721 but having trouble
To rtemove the nut, hold the fan blades,and at the same time undo the securing nut clockwise as though you were tightening it, as it is a left hand thread, and vice versa for tighteming it again
Please rate mhy solution.
Thankyou..
Posted on Jan 16, 2010
SOURCE: have a Neff b1432 oven
Neff B1432 circotherm oven.
The grill element has just been replaced but it only heats up to 150 degrees or medium heat.
The fan oven works perfectly well and heats up to 220 degrees.
Any suggestions ??
Many thanks
Posted on Aug 08, 2011
We cooked pizza at 500 something popped and now our oven cooks but not right , any ideas
If you have an electric range, look at both the top and bottom elements while oven is cold. Look for a rough spot like a hole in the element. You may have just burned out one of the elements. Sometimes they go bad without any marks. Turn on oven to about 350 and watch the bottom element to see if it gets red hot. Then set for broil and watch the top for the same red hot glow. If either does not glow red after 5 to 10 minutes, that element is bad.
Apr 02, 2016 | Ovens
Hello . i have a problem with my bottom oven ,the fan is working but the element behind the back panel in front of the fan does not seem to be glowing red. any ideas on this fault please?
It will be the oven element that has failed, a new one wiil need to be fitted.
It is located at the rear of the oven compartment behind a removeable cover.
Feb 21, 2010 | Neff U1721 Double circotherm Electric Oven
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Hotpoint UD47 electric oven not hot enough
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Ovens
Oven on fan setting not working ;fan is still working but oven is not getting hot on large oven
The oven element is faulty, and needs replacing.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Jan 12, 2010 | Neff U1452 Double circotherm plus Electric...
Neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Aug 25, 2009 | Neff B1421 Electric Single Oven
We are just about to have the heating element replaced in our Neff U1721 oven for the 5th time in 2.5 years!. Any answers
Have come across this problem before and it can be cured by replacing the fan motor. As the motor gets older it spins with less power and allows the element to get to hot and burn out. Replace your fan motor problem solved.
Jun 17, 2009 | Neff U1721 Double circotherm Electric Oven
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
Electric oven too hot
Apr 16, 2007 | Neff U1421 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
55 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
