Question about Tally T2340/24 Matrix Printer
Landscape printing on t2340
Trying to print windows file in landscape form. The printer is printing from top of page down to bottom instead of from left side to right side
    Sergeant:
  • 259 Answers
Printers>properties>general tab>printing preferences change print mode to landscape from portrait..........
Posted on Jan 23, 2013
  • nickandmary
    nickandmary Jan 24, 2013
    Thanks Mike but it is not printing in portrait mode. I have changed to landscape but that makes no difference. The print is actually rotated through ninety degrees, that's the weird part.
BondoFox
  • 40 Answers
SOURCE: Tally printer form feeding continually on its own
When was the last time it was services? It may be nothing more than a dirty paper sensor. Also, some Tally printer sensors require adjusting, it may be a simple matter of adjusting a sensor setting. That would require a technician with the manual and settings chart. Let me know how it goes!
Posted on May 29, 2007
  • 114 Answers
SOURCE: error in eject page
dont use LF use FF to forward a form. if you use LF then set the topper form again.
Posted on Jan 30, 2009
  • 114 Answers
SOURCE: Tally printer T6180 Printing problem
There are several reson behind the problem.
1. Check the driver settings & match it with the printer imulation.
2.Check the parallel cable.
If not solved connect the printer to a new pc.
some time computer's parallel port may damaged.
Posted on Jan 31, 2009
  • 169 Answers
SOURCE: Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Go to the FILE DROP DOWN MENU
  • Select SERVER PROPERTIES
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Posted on Oct 02, 2009
SOURCE: Using ASCII commands form IBM INFOPRINT to Tally T6218
download ethernet drivers
Posted on Dec 22, 2009
Print result sideways
It sounds like your printer is set to print landscape, instead of portrait mode. Next time you want to print, click on file(top left of screen), then print (don't just click on the little printer icon). This will open a new printer window where you can choose different setting. The option to change from landscape to portrait will be listed somewhere in that window. Once you have selected that feature and print it will stay that way unless you change it. You will have to check this setting in each computer program you use.
Jan 23, 2014 | Canon PIXMA MP160 All-In-One InkJet...
HP P2015DN Prints in Landscape form
Hi
sometimes just some of the printer drivers are with "bugs" like this one.
If you are using Win 7 or newer ver. please don't let the operation system to install drivers for this printer. Download drivers from www.hp.com and install it manual. Try different drivers. I'm sure that this will help to prevent "landscaping"pocvnqve445ajvwaaaaasuvork5cyii=
Good luck.
Pifonski
May 29, 2008 | HP LaserJet P2015dn Printer
Tally genicon 6605 is printing from top to bottom of the page...what could be the problem
I think it depends on what you mean by printing from top to bottom of the page.
If you are describing the print being rotated by 90 degrees so rather than a line of print going across the page from left to right, the print goes up and down the length of the page.
The most common cause of this is that you are printing from a Windows application and you have set the page orientation to LANDSCAPE rather than PORTRAIT.
With in the application you are printing from look for the PAGE SETUP options ensue you select PORTRAIT.
This should rotate the print.
Oct 18, 2013 | TallyGenicom Office Equipment & Supplies
I am trying to print on forms that are tractor fed and are 8 X 5 1/2, how do I adjust the printer so it will print on this size form. How do I adjust the printer to this size. I have already adjusted in...
select file at the top left hand corner of the page from the drop down list select page setup you should see a margins box you can make your adjustments in this box left.right.top.bottom also you might select print preview where you can look at the size and detail of the document you are about to print
hope this helps
Nov 24, 2010 | Office Equipment & Supplies
Jul 28, 2009 | Tally Line Matrix T6050 Printer
Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP 1280 Error message
well...the printer settings will be the key. open them up and make certain that you're tray assignments are in line with your A4 paper.
Aug 20, 2008 | HP DeskJet 1280 InkJet Printer
HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
Jul 29, 2008 | HP Officejet 6310 All-In-One InkJet...
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Printing landscape instead of portrait
this article may explain how to change it
http://hints.macworld.com/article.php?story=20070613051850612
Mar 05, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Tally T2340/24 Matrix Printer Logo
157 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
