Question about Pioneer Dolby Digital 5.1, Pro Logic II and DTS Surround Home Theater System, HTP-2700 System
How to hookup to u dvr dish reciever to pioneer surround sound
Pioneer dolby digital 5.1
  • 33 Answers
You will need to run the video cable to the telivision. You will need to take the digital feed from the dvr and run it into the pioneer digital input.
Posted on Jan 28, 2009
I hooked up a new lg hd tv via hdmi through my digital cable box. I am not receiving true surround sound, only dolby II. I have my box digitally hooked up to the receiver and the HDTV digitally hooked up...
It's possible that the TV broadcast isn't in true surround, and is only dolby encoded.
You can try going back to the component hookups, but I am not sure that will solve your issue.
Feb 27, 2011 | Panasonic SA-HE100 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Att uverse sound quality.
http://www.hdtvsupply.com/gefen-ext-homets-home-theater-scaler.html
The link above is how I fixed mine, because I love the way the functions of Uverse works. Here is the problem HDMI and Optical Dolby 5.1 are delivered in digital packets. The DVR at about 48000. These newer HDMI TV and surround sound receivers are processing the sound packets faster than the DVR can deliver it, and hence, when the TV speakers, (HDMI Source) or surround sound receiver optical source, run out of packets or only get 47999 packets from the DVR instead of 48000, there is a momentary drop out. This is either bad chipset in the DVR, or a sync problem with the software. Dish, Direct TV, and almost all of the cable companies have also had this problem. I had dish, and not only would the sound drop out on the HDMI, but I had to turn off the TV and turn it back on to get sound back. It took Dish about 2 years to fix this. Me I am going to ride it out, because I love the way the Uverse features work, and the honesty of the techs that mad my home visits. They told me that they were working on a software push and shooting for August 2010 to fix this. I am going to write ATT Corporate offices by certified mail RRR, and show them what I had to do to fix their false advertisement, and see if they will credit all or some of the cost of this scaler back to me. In the meantime, if you're not using anything but the TV, set your digital audio on the Uverse DVR off of surround back to stereo, and the dropouts will stop, or buy the scaler. It is an excellent workaround, and it also up converts the DVR's 1080 i signal to clean clear and crisp 1080 p, something ATT will never do. It will also convert the component stereo out into dolby digital sound to the HDMI and optical ins on your TV and receiver. THAT IS THE ONLY SOLUTION I HAVE.
Feb 09, 2009 | Audio Players & Recorders
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Choppy and distorted sound during gameplay with an optical cable
Check your pioneer unit settings, the ps3 settings are correct, and make sure you unplugged the audio cables. It sounds like a bad signal somewhere, which would cause the speakers to clip and distort. Make sure all of your surround sound speakers have a good connection if they have single wire runs to them and not a audio plug in them and there are not broken wires, or wires touching.
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
May 19, 2008 | Marantz SR-7200 Receiver
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Mar 13, 2017 | Jamo DVR-50 System
183 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
