Question about Yamaha Audio Players & Recorders
Hello, I have a brand new Yamaha RX-V 373. When I try to select inputs by pressing the selector on the front panel, I can only go through all of the inputs when pressing the right selector (with the arrow to the right). When using the left selector (arrow to the left) to go back through the inputs, the amp shuts off. Do you have any idea? Kind Regards, Erwin
    Genius:
  • Yamaha Master
  • 1,054 Answers
If it's new, I would take it in to have it serviced. Sounds like something is wrong on the front panel.
Posted on Jan 23, 2013
robotek
  • 1512 Answers
SOURCE: Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Posted on Feb 16, 2008
  • 151 Answers
SOURCE: Help setting up Yamaha RX-V461
USE A OPTIAL OR COAX DIGITAL LEAD FROM DVD 2 AMP ,SET AUDIO OUT ON DVD 2 BITSTREAM THEN AMP WILL DECODE DOLBY DIG AND DTS "6 ICONS ON AMP".
HOOK UP DVR WIYH PHONO CABLES AND SET DECODE MODE 2 PROLOGIC2 2 GET SURROUND SOUND.DO NOT USE AUTO SET UP FOR LEVELS AS MOST AMPS ARE NOT VERY GOOD AT THIS,USE THE TEST TONE AND YOUR EARS .
RULL OF THUMB SET FL,FR,CEN AT ZERO REARS +4 SUB AT 0.
TUNE RADIO 2 STATION THEN PRESS AND HOLD PRESET NUMBER TO LOCK IN I THINK!
HOPE THIS HELPS.
CABLE GUY.
Posted on May 20, 2008
robotek
  • 1512 Answers
SOURCE: Input selector keeps changing when select one
Hi goa_edc
Try resetting the amp by leaving it unplugged from the wall overnight, and then fire it up in the morning.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 13, 2008
SOURCE: Speaker output
Yes, there are relay type switches associated with those outputs. Your RX-V1 is not dying.
Just plug a pin plug in and out of the dead channel to bump the switch. You will hear the speaker
come on. If it doesn't come on,do the plug jack in an out of the pre out again. It will come on.
You can use the test tone to check all channels and rebalance volume levels. You are making the
pre out connect to its power amp. It seems the problem got better when activating those switches. Most likely a cleaning issue. You can also jump the mains and center, and there is also
a modification to jump all channels. I bought my RX-V1 very cheap because of this and love it.
Of course outboard power amp would solve all, but getting this reciever to connect to it's own
power amp has been thrilling as far as bang for the buck. I do use the front effects also, and like
them. It may seem like a pain, but it is worth it to get those channels going.
Posted on May 31, 2009
SOURCE: Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
I have the same issue. I took the speaker apart and tested with a meter and both the mid and tweater were wide open, in short blow out. Not sure what caused this but the speaker needs to be replaced.
Posted on Jan 14, 2011
How can I factory reset RX-V2092
Press MASTER ON/OFF on the front panel to
release it outward to the OFF position to turn
off this unit
Press and hold STRAIGHT on the front panel
and then press MASTER ON/OFF inward to
the ON position to turn on this unit.
This unit turns on, and the advanced setup menu
appears in the front panel display.
Rotate the PROGRAM selector on the front
panel to select "PRESET"
Press STRAIGHT on the front panel
repeatedly to select "RESET"
confirm your selection and turn off this unit
Dec 10, 2016 | Yamaha RX-V2092
Can't find hdmi input selection on Yamaha rxv1600
Depending on what you are connecting to your HDMI inputs, rotating the input selector on the front panel (or one of the input selector buttons on remote), to which you've assigned the component on HDMI 1 or HDMI 2 on the back panel should give you the connection. Make sure you have an HDMI component connected to it, and that you're using its HDMI out connector (eg. output of DVD to input on your Yamaha). Hope this helps.
Dec 10, 2013 | Yamaha RX-V1600 Receiver
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Oct 04, 2012 | Yamaha RX-V671
I have connected PC to Yamaha and to SonyTV all with HDMI cable and when I play movie on my PC I can see the picture on TV but I can`t hear sound. What shoul I check to solve this problem? Thank...
Page 40 of your owners manual....
Rotate the INPUT selector on the front panel
(or set the operation mode selector to AMP
and then press one of the input selector
buttons on the remote control) to select the
desired input source.
Oct 19, 2010 | Yamaha RX-V2700 Receiver
I NEED TO KNOW HOW TO RESET YAMAHA 5990
Page 88 in the Manual:
Under ADVANCED SETUP
1. Press Master On/Off to set the unit to the standby mode.
2. Press and hold STRAIGHT / EFECT on the front panel; and then press Master On/Off inward to the ON position to turn on the power to this unit.
3. Rotate the PROGRAM selector on the front panel to select the parameter you want to adjust.
The name of the selected parameter appears in the front panel display.
4. Rotate the PROGRAM selector on the front panel repeatedly to change the setting.
5. s Master On/Off on the front panel to release it toward the Off position to save the new settigns and set the unit to standby mode.
THIS is the parameter you want to find in the procedure above:
"PRESET"
Use to reset all the parameters of this unit to the initial factory settings with the exception of System Memory and AUTO SETUP settings.
Choices: CANCEL, RESET
* Select CANCEL if you do not want to reset the parameters of this unit.
* Select RESET to reset the parameters of this unit.
Mar 30, 2010 | Yamaha HTR-5990 Receiver
I own a Yamaha RX-V461 and since making a few changes, new Bravia TV and BLu-Ray DVD player, I no longer jhave sub woofer output. I bought a new sub woofer cable and even bought a new Polk 8" 300watt sub....
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Jan 24, 2010 | Yamaha RX-V461 AV Receiver
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
RX-V1600 when i turn on no sound or channels display on
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Jul 19, 2009 | Yamaha RX-V1800
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Hi Dush
regards
Graeme
Sep 16, 2007 | Yamaha RX-V596 Receiver
588 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
