Question about Technics Audio Players & Recorders
I have a Technics su-g88 that had no sound unless it was turned up to the max. I was told that the amp chips rsn 3305 and rsn 310r36 were bad. I purchased them and installed them and now I get the overload on the screen when I turn it on. I put the old ones back in and no overload on the display but the sound problem is back. I sent the chips back and got another set but they do the same thing. Is there something else that either of these chips could have taken out if they were indeed bad? I have tried this with and without the speakers so that is not the problem. I have also tried with the tuner unit hooked and with out and also have none of the other parts hooked(ex. cd, tape or eq units)
    Genius:
  • Technics Master
  • 1,054 Answers
Check the solder connections on the voltage regulators. They should be on the heatsink near the amp ic's. These have a tendency to break down over time.
Posted on Jan 23, 2013
  • 1 more comment
  • danny parks Jan 24, 2013
    they looked fine but i resoldered them but to no avail thought about replacing all the electrolite caps and most of the transisters that due the regulating
    also thought about trying a different compasny for the main amp chips
  • Steve K Jan 24, 2013
    Might also look at the connection on the rear panel jacks. Some of these are ground connections for the main board and if these are broken, they could cause problems.
SOURCE: Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Posted on Dec 01, 2007
SOURCE: Technics SU-G70 clicks but doesn't display or sound
I just got mine back from repair shop, same symtoms, they replaced power supply, in your case it was hit and miss for a while, so maybe bad power supply connections inside.
Posted on Jan 18, 2008
SOURCE: Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Posted on Apr 10, 2008
  • 5 Answers
SOURCE: Technics SU-G90 Amplifier from the
because bad connections, probably in the driver section of the endstage, dc current apears on the output and shuts down the output through the relay.
info@lustinvest.nl
Posted on Aug 25, 2008
CLARKPINK55
  • 71 Answers
SOURCE: Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Posted on Dec 08, 2008
Technics su x520
Most technics do not turn on the fan unless the volume is turned up pretty high.
Jun 06, 2013 | Audio Players & Recorders
Technics SU-G75 overload
I have the same problem..it will be required to remove the board and resolder "cold " solderings... None of above solutions have been helpful, but "you get what you paid for"..and I completely disagree...even if required, remove ALL audio power managing circuitry and replace this expensive original design with TI´s Integrated chips..using PWM technology..unless you want to go back to L6, ot Kts tubes..
Nov 07, 2012 | Technics SU-G75 Amplifier
Does the SU-G88 AMP carry a remote control and can you advise where I can buy one from? Is the amp for sale and how much?
Search engines would reveal those answers faster than waiting for one of us to do it for you.
It DOES use a remote.
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=SU-G88&uuid=A13093555179681
http://cgi.ebay.com/Technics-EUR646496-SADX930-SAAX730-SUG88-SAAX7-Remote-/260761453202
Fixya experts provide free advice that would otherwise not be available online or easy to locate, not sales or a proxy search engine service.
Jun 29, 2011 | Technics SUV500 2-Channel Amplifier
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
Technics SU-G88. When volume is wide open get small amnount of sound, as sugested I have already replaced the op ic IC602 and this did not help. Is it possible that both audio power modules bolted to the...
problem with electronics is there are so many possibilities! before changing the power amp i suggest u check all the paths from pre-amp to power amp. bad resistors cud be it, faulty capacitor cud be draining power to ground. insufficient power supply to final amp cud also be it. so before making any rash changing pls check all components including the power amp module.
Mar 14, 2010 | Technics Audio Players & Recorders
I have a technics su-g88 a/v control amp, when i turned it on today, everything lights up and works but no matter what device i choose to listen to i get no sound. worked fine 2 days ago, also the fan in...
some technics models use hybrid o/p i.cs and when they go faulty shutdown the o/p to both channels. it is also possible that the fan not working can also cause this fault
Feb 07, 2010 | Technics SUV500 2-Channel Amplifier
TECHNICS SU-V50
Hi max
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
Graeme
Feb 06, 2008 | Technics SUV500 2-Channel Amplifier
Jan 04, 2008 | Audio Players & Recorders
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
97 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
