Question about Hotpoint Washing Machines
When i turn the washing machine on all the lights flash
When i turn the washing machine all the lights flash then would stop and i could use the machine. i have turned it on today not all the lights were flashing but it does not seem to be stopping i have been trying since 9.oclock thismorning to get it to work can you help please
  • Hotpoint Master
  • 17,130 Answers
Possible there is some error on the control panel ,It is possible that moisture can make the processor within the panel to malfunction. You can remove the panel and check the harness and connectors, if there is presence of moisture use a dryer to warm off. Also check the connections to the door switch and valves. Otherwise the panel can be a suspect.
Posted on Jan 23, 2013
mumma_1
  • 903 Answers
SOURCE: wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Posted on Nov 24, 2008
SOURCE: indesit w123 washing machine
hi had a similiar problem on a year old washing machine after 3 engineers later who 1..put in a new circuit board...did not work 2...put in a heating element ...did not work 3...techican engineer..put in a new motor and repalced air pressure switch...bingo did work if your drum is turning slowly and does not wash how very well you may find ur motor is getting worn out..a problem..?? b careful they r £90 so make sure its that b 4 u change it my machine started to fill then almost immedately emptied out..then tured off then i had the flashing lights hope this is some help to u
Posted on May 29, 2007
SOURCE: Washing Machine stopped through cycle and now will not turn on
Unplug!!! NOW! I drained the water using a common garden hose, fill the hose with water and have some device turning it off like a trigger nozzle on the low end. Detach from the supply and put the supply end in the center of the tub under the softener dispenser. take the trigger nozzle off and watch the water drain without cups and buckets. Then wring out the clothes and put them aside, use the hose trick again for remaining water. Now get under the washer and detach and reattach the brown and white lead input to the rinse cycle motor. She is made in France so be gentle. Plug the machine in and set the machine down and turn it on. Push the >> button until you reach the spin cycle if it starts you have fixed it!! Put the clothes back in open a bottle of wine and try again.
Posted on Nov 05, 2007
SOURCE: hotpoint wma 50 flashing pre-wash
i had the same problem, the programmer inside the control panel had blown,
check the wiring hasnt pulled near the motor, sometimes an earth wire comes off apparently.
Posted on Feb 09, 2009
SOURCE: stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Posted on Jul 28, 2009
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Service m6500 after last wash the start button contiues to flash unable to use washer even if power is turned of
My washer did the same until i relalised that after the wash when light is flashing, turn control to stop position and wait until it stops flashing before turning machine off. Sometimes i have to turn control right around again for it to stop flashing but this is how it works.
Dec 07, 2008 | Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Stop light flashing
Dec 16, 2007 | Candy CN146 Front Load Washer
Washing Machines Logo
369 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
