Question about Singer 7422
Can't change needle/machine freezes!
Especially when I'm reverse stitching and then switch back to regular stitching, my machine will freeze, all the lights will flash and it will start beeping at me. The needle will jam when it does this. After one instance of this, I was trying to get the needle unjammed so I could remove the fabric and the needle broke. I don't know how to put on a new one! And I lost my manual... :( I tried removing the screw on the back of the needle but it didn't do much good except make the top of the needle visible. I also tried turning the little silver tab to the right of the needle, but it won't loosen in either direction and I don't want to break it more. Any help regarding putting a new needle on my machine, OR any ideas as to make it stop jamming/freaking out and having fits would be greatly appreciated! Thanks, Ana
  • meena1981 Nov 30, 2007
    when i start machine and starting sewing. Its not sewing and getting a beep and stop the sewing after that.
    Can you please help me in resolving this.
    Novelist:
    Scholar:
  • 84 Answers
Hi Ana...To remove/replace needles, loosen the screw on the right side that is attached to the Needle Clamp, which is located at the bottom of the Needle Bar. Your sewing machine should have come with a "kit" that included a small screwdriver. Use this screwdriver, or any compatible screwdriver to loosen the set screw by turning it "towards you" in a counter-clockwise direction. Discontinue turning once the screw is loose, and the needle clamp has a little play on it. While holding your replacement needle in your hand, observe that the top of the needle, which you insert into the needle clamp, has a flat side, and a round side. You want to have the round side facing you, and the flat side away from you to properly insert the needle. Ensure that you continue to apply upwards pressure on the needle until it stops, then finger tighten the Set Screw firmly, but there is no need to clamp down on it. Also observe that with the round side facing you, the majority of the remaining needle has a groove in it. This groove is designed to accomodate the thread as the needle penetrates the fabric, hence creating a hole diameter not in excess of the needle size. As for the physical malfunctioning of your machine I may need more specific information, including whether the beeping is continuous or not. If not continuous, count the number of beeps. If it beeps more than one cycle, count those beep numbers as well, and post the numbers here in chronological order. However, I suspect that the machine is simply running/sewing while you are locking your stitch by hitting the reverse. Normally, hitting reverse while sewing is not an issue, however, if your particular machine has the slightest Feed Dog timing flaw, it can cause needle breakage, fabric bunching, and lockups. So as a test, sew some scraps, and recreate your forward/reverse steps, but this time, do not press or release the reverse unless the machine is at a complete stop, and the needle is in the up position, and free of the fabric. You can manually move your needle vertically by turning the Balance (hand) Wheel located on the right of your machine. Note that should you have to manually turn the wheel to reposition your needle, always turn it in a counter-clockwise direction only......I hope these steps resolve your issues, but please update your post if we still have some work to do.....good luck my friend.
Posted on Aug 03, 2007
I used to have a Huskavarna that would lock up on me because one of the sensors thought the thread was broken. Your machine might need to be cleaned.
Posted on Jan 04, 2008
Back of fabric is all balled with thread
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top thread.
Test straight stitch.
For fraying thread, there is either a burr somewhere in the thread path or the needle is not correct for the thread. Sometimes the needle eye is too small for the thread and causes the thread to shred. Changing the type of needle (an embroidery needle, top stitch...) may help. Certain brand name threads work better or worse on certain machines. You might try changing thread brands. Avoid old or bargain bin threads.
All About Needles SCHMETZ Needles
Sewing Machine Needle Troubleshooting Guide SCHMETZ Needles
Feb 03, 2018 | Sewing Machines
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
1965 Singer 237. The needle suddenly freezes up when I change speed while stitching. Hand wheel and take-up lever continue to go up and down. What is causing the needle to freeze up?
Could be lack of fresh oil on the needlebar's moving parts. Use good quality sewing machine oil or liquid Tri-Flow Synthetic Lube and follow up with heated air from a hairdryer.
Jan 12, 2017 | Singer Sewing Machines
Needle hits the quilting presser foot
Needle may be slightly bent. Needle may not be properly or fully inserted into the needle clamp or holder. Needle may even have a burr on it or be too dull. Needles must be changed fairly often, especially with many of the modern synthetic fabrics. They do not last forever.
Change the needle first, for a new one, be sure it is properly inserted. Then, make sure you have not accidentally set your stitch width incorrectly. I've done that myself after using a zig zag stitch mode and forgetting to change it, or not change it all the way back to straight stitching.
Some machines will allow the needle to be set at centre, left of centre or right of centre, so be sure it's in the correct place for the stitch and foot you are using, or you will hit the foot.
Hope one of those turns out to be the right tip.
Oct 16, 2016 | Brother Sewing Machines
Is there a reverse switch? where
Depends on your machine. Consult your owner's manual.
On a lot of older machines, the Stitch Length Selector will reverse if the lever is pushed all the way up. Some really old machines do not have a reverse, so what you have to do is sink the needle in the fabric, lift the presser foot, and swivel the fabric 180 degrees so you can stitch back over the previous stitches.
Newer computerized machines will have a button, lever, or switch sometimes labeled with a reverse arrow.
Jul 15, 2015 | Sewing Machines
Needle won't go up and Down
Is this a Bernina machine with the needle stuck in the up position? If so, is the model something like a 930 or 1030 or similar?
I'll have a go at an answer but unless you give more information than this, it's not worth attempting.
Oct 17, 2014 | Sewing Machines
Usha flair model
If you check on your machine, there will be a switch or dial (depending on model) that also has a blue color. That is probably for stretch stitching. You will have to change the switch or dial to the stretch stitch setting and then you will get those stitches. No need to change the needle plate. You will only need to change to a ball point needle if you are stitching on knit. Otherwise a regular needle will be fine.
May 03, 2014 | Janome Sewing Machines
7570 Pfaff - stitch length
Make sure you raised the feed dogs.
Jul 23, 2008 | PfaFF Creative 7570
Singer 7422 Logo
193 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
