Question about Remote Starter with Keyless Entry
How to set run time and auto start time for a c705 bulldog remote car starter
MrScary66613
  • 1990 Answers
SOURCE: wirering deiagram
Go to The BulldogSecurity.com Website. They have online Wiring Solutions For EVERY Make and Model There
Posted on Jan 04, 2009
  • 27 Answers
SOURCE: No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
Posted on Jan 10, 2009
  • 1596 Answers
SOURCE: Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
Posted on Feb 12, 2009
SOURCE: Car stops after one minute
I found the solution to my problems was figuring out the correct wiring. I researched the wiring diagram for the vehicle I was working on and found five different ones that were all a little different and all wrong. The ignition 2 and 3 wires were listed wrong and so was the headlight relay diagram. Once I figured the correct wiring out for myself, it works great. I e-mailed Bulldog about it and they said thanks and sorry for my trouble. I haven't checked to see if they have corrected their diagram or not yet. I suggest finding the diagrams from several other sources and comparing. I would say you have the wrong secondary or accessory ignition wire connected. One way I knew the wiring wasn't complely right on mine was the fact that the heater didn't come on when the vehicle was started with the remote system. If you don't have that problem, it may just be the secondary and not the accessory ignition wire that's wrong. For me, I think it was both. Also, you may need the bypass module.
Posted on Apr 07, 2009
MECP Guy
  • 344 Answers
SOURCE: car remote starter wont work
www.bulldogsecurity.com
Posted on Sep 29, 2009
My heater fan won't work when car remotely started with Bulldog remote starter
The yellow wire at the ignition switch is not connected to the remote start system. Once it is connected to the accessory output of the remote start, it should work properly.
Jan 08, 2013 | Remote Starter with Keyless Entry
I bought a used truck with a bulldog remote starter in it but the guy has it set to start when it reaches a -10. I want to reset so only starts when I hit the button. The key fob looks alot like the rs...
PRESS AND HOLD THE BRAKE PEDEL, PRESS AND HOLD BUTTON 2 UNTIL PARKING LIGHTS FLASH 2 TIMES, RELEASE BUTTON 2 AND PRESS AND HOLD AGAIN UNTIL 2 FAST FLASHES ARE HEARD, RELEASE BRAKES AND LIGHTS WILL FLASH 3 TIMES, THERE ARE 7 DIFFERENT SETTINGS SO IT MIGHT A COUPLE SECONDS TO COMPLETE
Feb 01, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Bulldog Remote Start Problem
if thats a key resisor bypass i never heard of that, i would check with with bulldog to see if may be a set upproblem
Jan 24, 2010 | 2000 Chevrolet Impala
Have installed the Bulldog remote starter in my 2005 jeep liberty. I have to hit the button several times to get it started. I have already changed the jeep's battery.
There is some sort of a feedback to tell the starter if the unit is running - make sure you have the 'tach feedback' connected. There are settings for it to run the starter for specific length of time, or for it to know that it started by the tach feedback. Check your users' manual.
Dec 29, 2009 | Remote Starter with Keyless Entry
Bulldog Deluxe500 in '02 trailblazer will not start or reset.
unplug all harnesses going to unit for 5 min plug all harnesses back in and reprogram remote, you do not need to program for voltage sense, that is the factory defalt or call tech support at 1-800-878-8007
Dec 16, 2009 | DLX 500 Remote Car Starter
I bought a used Town and Country that came with this remote starter (Bulldog Model C705). How do I operate it? Can't find a manual online.
I have been installing bulldog units for a long time and have never heard of a C705 unit, you should call tech support at 1-800-878-8007
Dec 06, 2009 | Keyless Entry System with Two Remotes
How do I start my car?
If you mean to keep the car running once it's already been driven, and you want to have it remain running, but take your keys with you, put the vehicle in park, release the brake, with the key in the "run" position, push the same button you use to remote start the car. You'll have the relays click, and the parklights (if connected) will come on. Don't touch the brake!! Turn key to "lock" position, remove key. Vehicle should remain running for the set amount of time like normal remote start operation. You may now lock your car with the remote, too. When you return to your car, turn key to "run" position, when you step on brake pedal, the remote start will cease operation, and you can drive car as if you had remote started car from a standstill.
May 17, 2009 | DLX 500 Remote Car Starter
Bulldog Deluxe 500, remote not starting the the vehicle
Remove the battery in your remote for 15 sec, then put back in, start your car with your key, wait 15 sec, while the car is running press the * star button 2 times, it should beep , if not try it again, if still nothing post me back and we can go from there
Feb 22, 2009 | DLX 500 Remote Car Starter
Feb 12, 2009 | DLX 500 Remote Car Starter
Set up
Turn the valet switch on, start the car with your key wait 15 sec, press the * star button 2 times with the car running, it should beep and program if not turn valet switch the other way and try again, if still nothing post me back and we will go from there
Jan 15, 2009 | Bulldog& Remote Alarm System With 1-wire...
Remote Starter with Keyless Entry Logo
66 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
baire
john h
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
