Question about Siemens WXLM112GB Front Load Washer
Viberation at the time of spinning is a issue
  • Siemens Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
Posted on Jan 23, 2013
Excessive viberation from 70 mph up. viberation is dominate in the handlebars and footboards
Could be crank run out..handlebar rubbers ..neck bearing grease & check tention...
May 06, 2011 | Harley Davidson FLHTC - FLHTCI Electra...
When in low idle has a bad viberation seems to to less viberation when accelerating
Common problem. Check your motor mounts and transmission mounts, more than likely it's the motor mounts. While they may "look" OK from the outside, the mounts tend to crush and not be as high as they need to be. This problem has is just a nuisance and won't hurt the performance of your TB. Typically this problem will start out only happening when it's a cold engine, then go away once the engine has warmed up. But will get worse as time goes on. Buy OEM mounts as aftermarket mounts won't be as stiff and a lot of times end up with vibration quickly after they are replaced, so don't waste our money. Hope this helps! Good luck.
Jan 02, 2011 | 2005 Chevrolet Trailblazer Ext
During the lest spin cycle ,the drum spins like its out of balance, with bad knock , viberation. even after making sure the load is balanced in the drum. even without a load or water, (empty) it still...
The machine sounds as if it might be unsteady. If it only happens on the spin it is probably slight. Try levelling it at the feet, using a spirit level helps enormously to get it level.
Dec 09, 2010 | Washing Machines
Ford f250 viberation high speed 65mph
Check the U-joints and center carrier bearing on the drive line.
May 24, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Machine vibrates when spinning out
lower the legs as low as possible and lock the lock nuts on the legs this will control the viberation . but only if the floor is good. mm
Dec 13, 2009 | Maytag PAV2300 Top Load Washer
Viberation.
This sounds like a case of bad gas affecting your vehicle's smooth operation. Try going to an auto parts store and getting some gas treatment next time you need to fill up. Add it to your gas tank at that time, and it should help. I had the same problem, and this worked for me. Good luck!
Nov 11, 2008 | 2008 Toyota Camry
Viberation
Please check in the profiles , if the vibration is ON.
Jul 27, 2008 | Nokia N95 Cellular Phone
Siemens WXLM112GB Front Load Washer Logo
317 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
