Question about HP Qt318usaba Rp5800 I7-2600 3.4g 4gb 2x250gb Dos Pc
Rp5800 mic setup mic line in
Have you used a shotgun microphone before? Is there any changes you need to do in the recording setup to use shotguns?
First you need to get the understanding for the use of a shotgun mic.
It's ment to be used for movies, live recordings, and mic mixing.
So for mic mixing you need to get all the mics for the musicians leveled and then you mix the whole studio sound together by getting a level of how all sound is in sync.
I hope this was helpful.
Mar 02, 2015 | Audio Players & Recorders
How do you set up the mic on the samsung r519
Internal Mic or External? Open the Control Panel, open Sounds, setup mic. If external, do you have a setup disk? Have you setup the mic in Skype settings?
Apr 11, 2013 | Samsung R519-53S Notebook
Trouble with the feedback sensing system
Realize that only so much can be done to eliminate feedback by notching out frequencies. If you have incorrect mic setup, have EQ's set unreasonably, etc. the feedback suppression can only do so much.
Balancing the board out properly goes a long way to containing feedback. There are some pretty good videos on YouTube on proper setup of mixers.
Using mics that have a cardoid pattern and are out of the direct path of the main speakers and monitors is important. Amplified acoustical instruments are a real pain as it is hard to keep them out of the line of fire. Often the run these instruments to small amps and then mic the small amps up close.
The sensing system in this is a part of the whole system and is probably operating as it is supposed to, just not the way you want it...
Feb 03, 2011 | Yamaha Emx 5016cf 16 Ch 2x500w Powerd...
How do you use the microphone on the webcam without using the headset? i dont know how to activate the mic part of the camera
Hi Good day!!!
if your cam has a built in mic that should work fine. Try this: Click start lower left on your desk top, then click control panel then double click sounds and audio devices. Click audio tab ensure your speakers and mic are the default devices do the same with the voice tab. If not change them and click o.k. You can also check your equipment while you are there. Also click actions top line of the messenger window, scroll down and run voice setup.
Don't forget to vote Thanks!!!
Oct 29, 2010 | Computers & Internet
Getting the message "no input detected from your microphone" when trying to use yahoo voice
OK ..there are more than one scenarios here ..
First thing to check is the mike itself..tobe plugged well into the pink in ..and if it is a internal one I guess its ok ..
after that click on the icon shaped like a speaker in the tray system on the tsak bar (right click ) and open the volume control..if the microphone is not in the list ..click options in the left ..and properties...It will be displayed a list of devices..and you should choose from the list the mic..and check the square ...This will place it visible and activate it ...Check again the volume to be up ..for the mic..and not to be muted..
In this moment the mic is active and ok ...all that should be done its to see if it is picked up by the Yahoo...so ...open a conversation window with someone ..than in the action button ..choose call set-up ..it will show a window that has to be clicked next to make the call setup...first when you get to the mic setup...you have to make noise and do not move on until the level is moving and its says mic setup successful ...if it do not appears to detect the mic...see the device list in the window and choose the device you use...if themic is incorporated into the camera and it is a usb camera ..choose that from the device list ..after that make noise to be detected..and move on if it works .when you finish the setup with success it will work and you already can make calls
If teh other has issues in hearing you ..you can always go to the volume control center (like the first time ) ..and choose advanced under the options ..and after that in advanced under the mic line ...click to boost it up..and will double the fidelity ..
Have a nice day and please rate me ..1
May 30, 2010 | Computers & Internet
Behringer MX 3242x Mic input not working
Unfortunately, the way the mic preamp and gain control are surface mount components on the PCBoard, it's unlikely you'll be able to do it yourself. Best take it to an authorized Mackie repair shop, or send it back to Mackie.
Jul 29, 2009 | Audio Players & Recorders
Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Apr 21, 2009 | Computers & Internet
PS3 American idol encore 2 mic problem
I GOT THIS TO WORK.
First, make sure ur PS3 system update is full updated.
1) Turn on PS3
2) make sure all the mics were unplugged
3) plug one mic in
4) accessories setting -> audio device
5) select logitech as input
6) plug in the second mic
7) accessories setting -> audio device
8) scroll thru the input device, make sure it lists both logitech, this makes both mics are sync'ed to ur PS3
9) select the FIRST logitech device in input device
10) save setting, restart ur PS3
11) start the game as usual
12) in duet mode, both mics should show, if one is working and the second one doesn't, one forum suggests that u unplug the one that works and replug it while u are still in the menu.
Works for me, I hope it works for you. Cheers.
Jan 01, 2009 | Konami Karaoke Revolution: American Idol...
Headset Problem Rosetta Stone
3.Open Sound
Dec 27, 2008 | Rosetta Stone Chinese Mandarin Level I &...
HP Qt318usaba Rp5800 I7-2600 3.4g 4gb 2x250gb Dos Pc Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
