Question about Acer Aspire M3710
How do i restore my acer aspire M3710 back to its factory settings without a disk?
My pc randomly switches off. and has problem turning on. i think its from the setup files
    Problem Solver:
  • 12 Answers
The Windows (or other OS) settings would not prevent it from turning on. Based on your info:
Power supply - could be intermittent or overheating. Check that the fan spins. If the power supply fan has a squealing or grinding sound, then the fan is going out and could be stopping some of the time causing overheating. Also check the heat output by holding your hand by the fan exhaust and see if its overly hot. That could also shut it down intermittently.
CPU - overheating is possible. Many systems have shutdown temperatures to protect from overheating. Check that the fan spins up and is not plugged up with dust. If it squeals or grinds or makes abnormal noise, replace it because it will freeze in the near future. If you've separated the CPU from the fan recently, maybe the thermal paste wasn't applied fresh or properly. If you go into the BIOS, many computers allow you to view the temperature, voltages, etc., so you can check if its a CPU temperature problem. There are also many free programs that will monitor your computer temperatures and display them in the system tray. I can also suggest a program that will tell you everything about your computer (temps are under sensors):
www.gtopala.com
However, if you want to restore your computer, many have a restore option on the bootup splash screen. To save on the cost of DVD's, they create a "restore" partition on the hard drive. Sometimes the restore function will save existing data by restoring Windows only, without erasing the hard drive first. You will get ample warning if it will erase your data. If you don't have a restore function, then you'd have to buy restore disks from the computer manufacturer. The usually run less than $30.
Posted on Jan 23, 2013
  • kennedy amadi Jan 23, 2013
    My fans are working fine.... But what I mean is, my computer has corrupted "boot up" files, and it randomly switches off, so what I'm asking is, is there a way to reinstall the boot up files?
5 Suggested Answers
bootz84
  • 197 Answers
SOURCE: I want to restore my Acer Aspire M1100 desktop
You'll have to use your recovery disk to set it back to factory, unfortunately most recovery disks give you little or no options for which software is to be reinstalled. The only way to install windows without any of the extra software that your computer came with would be to take a standard windows installation disk and install through that. Afterwards you would have to manually install all the driver software.
Alternatively, you can install with your recovery disk and use the add/remove software feature in the control panel to remove any programs that you do not want, just be sure that you don't remove any software that is a driver for any hardware devices.
Hope this helps, get back to me if you need any more information.
Posted on May 06, 2009
NitrusInc
  • 326 Answers
SOURCE: WILL not resetting to factory settings
You will need to burn a Recovery CD / DVD set from the icon located on the desktop/ In your Acer Home Start utility (The window loading at startup) or from the Start Menu.
Using this disk you will be able to do a System Restore back to original factory setup.
Posted on Apr 14, 2009
  • 355 Answers
SOURCE: how do i restore to factory settings on my acer
nothing is losing while restore the machine
to restore the machine goto
start
programs
Accessories
system tools
system restore
select the older date to restore
then ok
bye
Posted on Nov 05, 2009
  • 2427 Answers
SOURCE: Acer Aspire SA80 desktop: Trying to recover PC to Factory Setting
The error your getting means leaking memory,, replace the rams and it will complete restore..
NTLDR is part of the booting system of the computer..basically the computer cant find the file..
Contine with the system recover after you change the rams,, you'll be fine..
Posted on Mar 13, 2010
Acer Aspire One D250-08K Need to restore to factory settings and i have no disc. Screen is black. On start up pressed ALT F10 then nothing happens
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Aug 29, 2011 | Acer Aspire One PC Notebook
Hi, i have an acer aspire one with windows xp home edition 2002, i need to reset it back to factory settings, but i have now disk to put it on there. how do i restore it to factory settings without a disk
have an acer aspire one with windows xp home edition 2002, i need to reset it back to factory settings, but i have now disk to put it on there. how do i restore it to factory settings without a disk ?
Use system restore and add/remove program to use system restore go to start ---> all programs
---> accessories ---> sytem tools ---> system restore .. restore your computer in earlier time...
to go to add and remove program click start ---> control panel and find add/remove program
remove the program you did not have when its new...
hope it helps god bless
Jun 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
I want to take my acer aspire back to the factory setting but dont have a cd how do i do it
Acer are cheap and they don't provide you with a factory restore disk. You need to make this factory disk yourself. I know how to do this, but it is to much for me to type and here is a really really good reference site for you to visit to get instruction to make your own factory restore disk. After making that restore disc,  pop the disk into your laptop and turn of your laptop and restart and the factory restore program should start, if it should not start then go into your bios menu and have it boot from your Dvd-Rom and save, after full restoration, make sure you turn your boot priority back to where your Os is being installed, exm hard drive.
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
Jan 14, 2011 | Acer Computers & Internet
How to format acer aspire 5315 without disk? its so slow!
Formatting without disc is slow on all laptop brand.
If you want a fast formatting use the installation disc.
Thanks.
Jul 26, 2010 | Acer Aspire 5315 Notebook
I want to restore my acer aspire 5920 to factory settings without disk.also a toshiba recovery disc was tried so now it thinks its a toshiba. help please
Hi There ,
Try restoring from restore point if possible. You should be able to pick a date and restore. If it came with restore cd or if there is a seprate partition on the hard drive you could also use that...
Hope this helps
Nov 15, 2009 | Acer Aspire 5920-6727 Notebook
ACER Aspire 3610 Wireless and Blootooth Switches
if you have a system restore disk, restore the settings back to the factory presets. XP System restore could help you, but the restore disk is usually the end result
Sep 05, 2009 | Acer Aspire 3610 Notebook
Restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Apr 13, 2009 | Acer Aspire 4520-5141 Notebook
Need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
Aug 20, 2008 | Acer Aspire™ T180 PC Desktop
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
Acer Aspire M3710 Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
