Samsung flat screen tv lost power. Now has no power. Outlet is okay.
    Genius:
  • 1,669 Answers
Try checking inside for a main fuse.
Posted on Jan 23, 2013
4 Suggested Answers
  • 11 Answers
SOURCE: How to clean a Samsung flat panel TV screen?
Only with the cleaning cloth provided....
Posted on Jul 31, 2008
SOURCE: samsung flat screen tv lost sound
Samsung flat screen lost sound - what is the problem? help!
Posted on Feb 21, 2009
  • 11 Answers
SOURCE: Panasonic flat panel just lost power while on,
Me the same some one please help!!
Posted on Mar 20, 2010
Samsung flat-screen TV model LNR328WX/XAA has no picture. Sound is okay. I suspect the power supply board has failed, and would to confirm that, before I order a replacement board.
I would definitely check on the SOURCE button on your remote control, set accordingly first. EXAMPLE#1: HDMI (1) / HDMI (2) or (3) or (4) / Component inputs, EXAMPLE: GAMES LIKE A X-BOX / Check the Regular TV input. Good Luck.
Jul 05, 2017 | Samsung Televison & Video
How do i fix
Most caused by deformed capacitor / or faltering resistor problems.
bulged because of the to tight tolerance in power voltage and resistors in priority the green colored 3 watt type resistors can have thermical faltering.
Mar 06, 2016 | Samsung Televison & Video
My screen turned blue and I can't change it back.
Try unplugging it from the wall outlet. Press the power button once to release any stored power. Plug it back into the wall outlet and turn power back on to see if this helps. If it is connected to a cable box make sure all the cables and connections are not loose. Check to see if the cable box is loose from the wall outlet.
Mar 31, 2015 | Samsung UN46D7000 46 Inch 3D 1080p Smart...
Samsung PN58B540 RED SCREEN
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 17, 2012 | Samsung PN58B540 58 in. Plasma HDTV
NOT GETTING ANY POWER WHEN TURN ON/no red light when hook to power outlet? checked power source okay. just bought this led tv about 3-4 months ago.
Possible that the mP section is not working , As confirmed the power supply SMPS unit is working but the secondary voltages must be checked to see if the regulator for the processor gets the supply. If not check and replace, if supply is through then the mP must be checked.
Need to check is warranty cover is availabel to you , if so call without tampering.
Sep 30, 2010 | Samsung LN32A330 32 in. LCD TV
Samsung 50in. flat screen lost all power
IF YOU HAVE NO LED STATUS, THEN IT'S THE POWER SUPPLY
Dec 23, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung lcd tv
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Gateway flat panel TV will not turn on, the front on and off switch doesnt work at all and when you use the switch in the back the front on and off switch lights up but tv still will not turn on. Is
This sounds like you have lost your power supply. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly. If this does not work, please try our premium service or use our online listing of technician for a professional near you.
thanks and good luck :)
Jun 20, 2008 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
