Question about Clarion Car Audio & Video
2008 Suzuki Jimny radio won't work on AM radio
The radio has stopped working on AM stations, when auto search is used it continues going around, when used manually will not pick up any AM stations. Fm stations can still be picked up
  • 47 Answers
SOURCE: Mazda MPV Radio Problem
THE GROUNDING ON THE ANTENNA REPLACE THE WIRE AND ANTENNA MAS
Posted on May 13, 2008
merle840
  • 113 Answers
SOURCE: Pioneer DEH 1900 MP receiver - cannot pick up AM stations
normally the problem you are describing means that your antenna is bad. typically, if you have no am good fm bad antenna if you had good am and no fm the fm section of your radio would be bad.
you can test this but you will need an antenna (this can be purchased at most car parts stores for about $10.00) pull out the radio unplug the black round plug from the back of the radio and plug in the new one ( the antenna plug is a universal fit) you will probably need to ground the base of the antenna for the test then turn your radio I'm sure this will fix your problem but if not you can e-mail me at merle840@aol.com
good luck'
Merle
Posted on Oct 01, 2008
SOURCE: Change from manual to seek FM stations
press and hold left/right functions.
Posted on Nov 09, 2008
TOLhamRadio
  • 509 Answers
SOURCE: 2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Posted on Aug 02, 2009
SOURCE: The FM stations are not playing in my 1996 Nissan Maxima.
make sure the antenna is plugged into the back of the factory radio.
Posted on Jan 05, 2010
07 suzuki forenza's trunk open light won't go off
Search Results
    2006 Suzuki Forenza trunk open warning light in dash won't ...
    answers.edmunds.com > Edmunds Answers
    Sep 15, 2008 - every so often it will if i hit the right bump ... I'd guess that this is a problem in the trunk itself, with the switch that activates the light. Press up and .
Oct 15, 2012 | 2006 Suzuki Forenza
I dont know how to program radio stations on my kenwood kdc-252u
If you are using auto search, the station you want on 98.3 may not be strong enough in that location. I had the same problem. If I drove to where the signal was strong enough, I could program it. That worked fine until the next time I had to program stations and the routine had to be repeated. Try driving around to find a "hot" signal location.
Sep 15, 2012 | Kenwood KDC-252U
THERE IS NO SOUND IN MY RADIO AUTO CD
go to radio shack and let them pop it open and they will work on it.
Jul 01, 2012 | 2005 Suzuki Jimny Cabriolet
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
Radio not getting stations
you may have a faulty radio unit. they really should have verified their work prior to it leaving. TAKE IT BACK! make them make it right!! happy holidays
Dec 30, 2009 | 2009 Chevrolet Cobalt
Car Audio & Video Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
