Question about Canon Digital Copier/Printer
Canon 2318l Poor, faded print quality on the right and left side of paper
SOURCE: Canon MP460 feeds the paper into the printer
I just got mine sorted out. It took two things:
a. luck
b. a lot of googling
Now,
The problem was 15 cents of the Euro in the following configuration: 1x10cent coin and 1x 5 cent coin...
The first thing I did was try to clean the bottom plate and the roller. I read somewhere that using some thick paper does the trick. I destroyed an office paper file (not very thick, but definately thicker than normal papers) - about 5 - 6 tries on the bottom plate clean and the roller clean, and a 5 cent coin appeared out of nowhere :)
I though that was it but I was very very wrong. At about the same time, I got the mother of all annoying canon error 5100. Although the heads moved at starting of the printer, when it came to print it had the error. I looked as much as I could and I was convinced (several times) that there was nothing in the printer. The heads moved fine, but the error was there. Rebooted the printer about 50 times, took power off etc, but nothing.
After a good 5' search with the flashlight (mobile phone) I spotted a small shine right where the little spongy thing is under where the heads rest far right when you look inside from the front of the printer. And voila, a 10 cent coin standing glorious in there and causing me all this trouble. I couldnt access it at all, but I was able to use the force of gravity (by inverting and giving a little jiggle to the printer) to get it to drop and finally got it out.
The printer works fine now, paper loads like a charm and even colour photo printing is fine.
Now I need to find a way to put back that little plate I took out (totally unecessary in the end...) and I have to sort out the removal of tons of ink from my hands.
To sum up:
It can be fixed. It's a pain in the ****. You might get richer (15cents for me!!!). You will have a full functioning MP460 printer again.
I hope this helps someone else as well :)
Posted on Mar 19, 2009
SOURCE: I have a Canon iP2600. For no apparent reason, it
Sounds like an obstruction of some sort. Have a look on the left side with a flashlight as best you can, and see if maybe a staple or paperclip got lodged in there.
Posted on Apr 27, 2009
bootz84
  • 197 Answers
SOURCE: Poor print quality .... Canon Pixma MP140 ...
Paper quality does make a difference in the quality of print, but it's usually in the areas of blurriness and vibrance. If your prints are coming out faded, the quality for your prints might be set to 'economy', which doesn't use very much ink. If you have it set for 'quality' prints, I would try replacing the ink cartridges.
Posted on May 08, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
  • 8 Answers
SOURCE: poor color quality (Canon Pixma pro 9500)
recalibrate the printhead, clean the printhead. In the printer driver you need to select the right paper.
Posted on Jun 09, 2010
Canon ip4850 print quality
Whats the question?? if poor quality printing, it could be dirty ink cartridges, dirt on the print head, poor quality paper ??? try looking at the printer settings, sometimes they may be set to economy rather than top quality printing.
Feb 18, 2015 | Canon IP4850 Inkjet Photo Printer
Printing problem on a Konica Minolta 2530DL. Was printing fine until we printed a set of thick labels. Now the print quality is really poor on the right side of the paper. It is both streaking and...
sounds like a lable has gotten stuck in the fixing unit, you may need a tech to remove it, do not use any sharp tools to remove it ,this could cause damage to your roller,
good luck, tinyman
Jul 19, 2011 | Konica Minolta Magicolor 2530 DL Laser...
Poor color quality (Canon Pixma pro 9500)
Jun 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Poor print quality....bad fuser???
Is the toner sticking to the paper? This could produce double images (but not mirrored) More likely a problem with a mirror in the write unit out of place, which could create "mirror" image and poor quality.
Jun 09, 2009 | Brother HL-6050DN Laser Printer
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
May 30, 2009 | HP LaserJet 8550 Printer
May 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
PHOTO APPEARANCE
Check your printer settings, If your printer is set on draft mode the prints may appear faded washed out, turn up the quality of the printing and this should solve the problem.
Feb 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Digital Copier/Printer Logo
48 people viewed this question
old marine
old marine
