Capacity for maytag lat9606aae - Washing Machines
What is the load capacity of Maytag LDE8904ACE
"Maytag Neptune High Efficiency 3.3 Cu. Ft. Capacity
May 25, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
Sep 23, 2010 | Maytag LAT2600A Top Load Washer
Water sloshing over top of washing machine tub.
I have the same problem model lat5006 still no answer
Jul 31, 2010 | Maytag Washing Machines
Washer fills with water, but does not agitate or spin rinse
This could be bad door switch or bad timer. You need to test it with a multimeter
Mar 31, 2009 | Whirlpool LHW0050PQ Front Load Washer
What is the capacity of the maytag neptune mdg4000aw
motor 1/2 horse power,,,electrical,,120 60 hz,,15 amp breaker needed,,weight 160 lbs,,,capacity 3.2 cubic feet..about 26 pounds...onthe job
Jan 18, 2009 | Maytag Dryers
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag washer, lat9606aae only works in delicate cycle and hand washable
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Dec 18, 2007 | Washing Machines
Washing Machines Logo
370 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
