Question about Maytag Dryers
How to route belt around pulley and idler
Model LDE7600ACW maytag elec dryer
Resolved problem by obtaining schematic showing proper routing........
Posted on Jan 28, 2009
  • 3 Answers
Repairclinic.com
Hi i have a maytag elec dryer it dosen't turn on anymore checked power cord checked fuse box model number MEDC300BW0 DON'T KNOW WHAT ELSE TO DO
-Mostly the timer is bad.
-Check it out and if effect then replace it.
-Possibly amazon carry it if you can have part number on it.
Good luck
Mai
Nov 27, 2017 | Maytag Dryers
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Maytag elec dryer belt broke / how do you open and replace
Remove the 2 screws on the bottom of the front panel to remove the panel and gain access to the drum.
Nov 22, 2012 | Maytag Dryers
Maytag elec dryer no start
i choose that because its meant for that purpose,of fast and easy tap controls and serving.producing great results.
Apr 01, 2012 | Maytag SDE4606A Electric Dryer
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Maytag dryer makes loud squeeling noise when it gets hot. Drys clothes but makes such a loud squeeling noise. Have to let it cool down to continue to dry.
Hi and welcome to FixYa, I am Kelly.
A loud squeal is usually caused by either an idler pulley bearing. a drum roller bearing or a loose belt.
Since you did not include a model number I have to respond with generic across the board information. Idler pulleys, drum rollers and belts for Maytags can be found on this link:
(Just past half way down the page) http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drive+Belts+Idler+Pulleys+and+Support+Rollers/default.aspx
You can enter your model number on this page and find your parts: (Choose model number)
http://www.appliancepartspros.com
If you do repair it yourself.... do yourself a HUGE favor and either take a picture of the belt routing or draw a belt routing diagram BEFORE dis-assembly.
Thanks for choosing FixYa,
Kelly
Jun 08, 2011 | Maytag Dryers
Can i get manual for maytag neptune elec dryer model number mde3000aya
You can obtain a FREE copy of the user's manual at managemylife.com. Type in the model number "MDE3000" under their "Manuals" link and you will find a manual available in .pdf format. Here is a direct link:
http://www.managemylife.com/mmh/owner_manuals/11455/MAYTAG-Residential-Dryer-L0807349?brand_name_search=mde3000
I hope this helps you.
May 05, 2011 | Maytag Dryers
I took the dryer apart and lubercated the belt and now I cant put the belt back on. How do I do this?
Hi buttcrackplu...
The belt will go around the drum,around the motor and idler pulleys....
Go to this webpage to see how the belt is routed.
Free Answer.,..Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Apr 18, 2011 | Maytag Neptune MDE4000 Electric Dryer
How do I open it to get access to change the belt?
All maytags i have encountered open from the front. There should be two screws at the bottom of the front or under opening of door. The top pops off and opens up to lay back. Swing front over to side of machine being carfull of door switch wiring.Look through botttom of dryer and you will see motor and idler pulley setup. belt is routed around drum, under pulley and around motor shaft. Hope this helps.
Dec 25, 2010 | Maytag PYE2300AY Electric Dryer
Dryers Logo
539 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
