Question about Zanussi Washing Machines
My zanussi WDT1072 does not spin the clothes dry any more. What could be the causes?
WDT 1072 washer dryer. It appears to be the spin that is at fault. I have removed the top and felt that the drive belt is not slack.
  • Charles Jan 23, 2013
    1. Washes normally - clothes tumble both ways.
    2. Spins one way at what appears to be normal speed.
  • Zanussi Master
  • 17,130 Answers
Check the drive for friction, it must move freely with your hand movement. If not it is possible that the bearing or accumulation of dirt has caused this to happen which can result in LOW RPM and thus the speed is less for drying .
Click On : Bearings
Posted on Jan 23, 2013
5 Suggested Answers
vest6
  • 196 Answers
SOURCE: broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Posted on Jan 08, 2008
SearsTechToo
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
  • 1122 Answers
SOURCE: kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Posted on Dec 06, 2008
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
My model is zanussi easy iron washing machine capacity 6 kg spin 1400 ,my problem is that clothes are not getting dried, water remains in the clothes, what is the problem .
Your washing machine has a problem with the water unless it is washer-dryer. Water remains in the appliance because drain pump is not functioning properly and laundry is wet.
Dado
Mar 16, 2015 | Zanussi Washing Machines
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
The heat is there but it doesnt dry the clothes
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
Nov 27, 2013 | Zanussi TC7114W Electric Dryer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
GE front load dryer
Clothing gets caught in the front of the dryer as it spins. This is leaving black marks and wholes in our clothing.
Apr 06, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Long time to dry
Check drain filter on front of machine and check machine is doing full spin. Regards Advisor
Aug 20, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
159 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
