Question about Dishwashers
When my Miele G1120 dishwasher is started, water starts to come through air inlet
When my dishwasher is started, water starts to come through air inlet and water does not spray through spray arms and it does not go through wash/rinse, drying process.However,after some times I can hear the water drains out and it does not remain in the wash cabinet. Programme does not end and wash/rinse, drying and end indicator lights flash simultaneously.Please help me to fix this problem
  • 641 Answers
SOURCE: dishwasher does not complete cycle
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 09, 2007
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
reverendrave
  • 24 Answers
SOURCE: MIELE INTEGRATED DISHWASHER WONT TAKE IN WATER
Contact Miele at (800) 843-7231
They will walk you through entering service mode on the machine to diagnose the fault code by pressing a series of buttons. At that point they can let you know what exactly is wrong with you machine
Posted on Sep 17, 2009
joe_lishman
  • 192 Answers
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
  • 177 Answers
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Posted on Mar 02, 2010
Miele dishwasher doesn't start Shows inlet
I am working on a similar problem. You need to refer to different info depending on the model. Do an internet search on
2011-11-25_043923_g600__800_miele_service_manual.pdf
You will probably find a lot of "experts" blowing smoke but this should help keep them honest.
Jan 24, 2013 | Dishwashers
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
How do I replace water inlet control valve on a Miele G851 SCI
there is a box on the end of your inlet hose that contains two solenoids. that is called your water proof system hose. when you try to start a cycle, that box should vibrate as the solenoids get power and try to let the water in. if it vibrates, but no water passes, you need to replace the hose. the only place to get one is through miele. 800 843 7231, press 0 and ask for parts.
May 30, 2012 | Miele Dishwashers
Hello. My dishwasher (Miele G 579 SC) does not fill water enough. When filling is done I must fill manually with a bucket to get water to a sufficient level. What might be the problem? Kind regards...
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 05, 2011 | Miele Dishwashers
I have a Miele SCU 648. The "start" and "end"(or
It is possible that a low water pressure can increase the time for the program and so this can lead to the program contrroller hanging up to show the flashing.
So remove the inlet and the water line to the inlet, check the filter and the inlet valve. If the pressure seems good , check the flow when the program starts.
Also counter check on the water level sensor, the drain pump/valve. finally check the winding on the heater using a multimeter, check the power to the heater during the program.
May 03, 2011 | Miele Dishwashers
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Does anyone know why a Miele diswasher will start to wash fine and then stop with the inlet/drain light flashing after a few mins? I looked at the pressure stat at the bottom of motor and when i blow in it...
hi,
you may have something rapped around the impellers of the circulation pump causing low water pressure. the unit will start and stop to try to clear the blockage. if the circulation pump is really jammed the inlet/drain light will light. it could be a faulty pressure switch but they are not common to fail.
Hope this helps
May 21, 2010 | Miele 24 in. G638 Plus Free-standing...
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
