Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Reset resolution for syncmaster 913v - Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
  • 547 Answers
SOURCE: samsung syncmaster 913v gives message
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Posted on Oct 03, 2010
  • 19 Answers
SOURCE: Monitor syncMaster 913v
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor to the nearest samsung's service center.
Best regards
Posted on Jan 17, 2008
  • 461 Answers
SOURCE: Syncmaster 913v color problem
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Posted on Feb 14, 2009
  • 14 Answers
SOURCE: Samsung SyncMaster 913V it's displaying red lines
Sometimes this happens when the pins on the vga connector are bent. You can either try to straighten them (very carefully with tweezers) - be sure to check both ends, or try a new cable.
Posted on Apr 06, 2009
rj_8017
  • 22 Answers
SOURCE: samsung syncmaster 913v has no image power light flashing
replace capacitors 1000mf/25v 470mf/25v...
Posted on Jan 23, 2010
My Samsung SyncMaster 913V (Black) 19 in. Flat Panel LCD Monitor, does not work correctly. Every time I reboot my computer the screen only works for a few seconds and after that it gets black and a...
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Apr 15, 2017 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung syncmaster 913v gives message ' not optimum mode"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Apr 06, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Feb 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor syncMaster 913v wont run 1280 1040 Resolution has in past goes blank moving "box- message' says ajust to 1280 1040 resolution Runs on other resolution settings ok
Dear
Best regards
Jan 08, 2008 | Samsung SyncMaster 913V 19" LCD Monitor
Resolution Issue "Not Optimum"
Hi Guys.
I have had this problem and after a bit of searching found that it is a known problem.
Give Samsung a ring and if it's in warranty they will replace it
Jan 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
77 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
