Question about Whirlpool LEW0050P Electric Dryer
Drum will not rotate in LEW0050p Dryer
The blower comes on, but drum will not rotate. I have checked the belt and belt is intact. Wondering if you have a list of possible causes that I can check before calling repairman.
  • Whirlpool Master
  • 1,525 Answers
Hello is the door making the switch if thats ok check wires see if any are loose if thats ok .at the bottom of the machine next to the motor theres a part callled a capacitor its got 2 wires coming off it this can stop the dryer rotating i hope this help
Posted on Jan 30, 2009
Dryer has electricity but the drum will not spin
Hello there:
If your dryer doesn't tumble, check these:
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 27, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer does not turn, but will turn by hand, how do you unlock heller cd55 dryer?
It won't tumble If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dec 31, 2009 | Dryers
Is it easy to install a new blower motor for a Whirlpool LEW0050P Electric Dryer? We have the part coming in today.
remove the front panel,then the top cover, remove drum belt,then the drum, and there it will be in the bottom of the unit
Oct 29, 2009 | Whirlpool LEW0050P Electric Dryer
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 | Dryers
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Whirlpool Ultimate care ii Dryer wont tumble
Belt,
Motor,
Door switch.
Remove the belt,
Check for obstructions in the blower fan housing,
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore electric dryer
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Dryers
Maytag drum
Belt
Motor
Door switch
  • Remove the belt.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
Belt
Motor
Door switch
  • Remove the belt.
Jun 15, 2008 | Magic Chef Dryers
Whirlpool LEW0050P Electric Dryer Logo
147 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
