Keybad of Thermotron 2800 Programmer Controller Manual
DS161 controller Can you change operation so works with out brake with out programmer or another way For merits scooter Thanks
If I understand your question, you would like to run your scooter without an electromagnetic brake. This is never a good idea. The controller looks electronically for the brake resistance of between 40 and 60 ohms before it will allow the motor to work. Theoretically you could put a resistor in series to fool the controller. With a programmer you can adjust the braking parameters and specifications and possibly defeat the function. I have not tried this since it is unsafe. Invest in a new brake for your scooter and you will live long and prosper. Hope this helps.
Jul 23, 2016 | Health & Beauty
How do I adjust the controller on a Prestige Four Wheel Mobility Scooter?
hi, adjust the controller, sadly that not possible with out a tool or recommended, a compatible programmer for the controller will be required, can i ask why you want to do this ?
Regards
Rob
www.gewizrepairs.co.uk
Jan 14, 2015 | Health & Beauty
Error code e000602
Mounting fault of the HDD.Viring faulty.The main controller PCB faulty.Wiring between connector J1025 of the main controller PCB and the connectorJ 2005 of HDD,or try reinstall the system software,or try to replace HDD and download the system software,or replace the main controller PCB...
Sep 25, 2014 | Canon gpr-6 ir 2200/2800 drum...
Boiler Programmer user manual
contat worcester bosch they will be happy to send you a manual as you already have there product installed.
Dec 11, 2012 | Water Heaters
The washer fill but no program would start
**WARNING!!! Unplug appliances before beginning repairs!!!!
You need a new programmer (Controller). The motor is jammed or not running. Very common. Controllers cost $75 to $300 dollars US. Find out the price before you order it!
Getting the knob off the controller can be hard. I suggest a new knob with the controller if it will not pull off or unscrew backwards. Special tools may be required.
Most controllers are easy to change inside as they plug in.
Mar 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
CTM HS 2800 2 yellow lights flashing after new batteries install
As her to explan to you how she recharges the batteries and how often she recharges the batteris, make sure she is following the owners manual. http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-2800%202800.pdf Explan to her the batteries can NOT Overcharge, Also trace the wiring for breaks or disconnections.
Sep 04, 2009 | Ctm HS-2800 Power Wheelchair
252 people viewed this question
k24674
jasbo
jasbo
