Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool LSQ9244EQO washer is leaking
Tile floor is wet underneath the washer. It was noticed in the spin mode.
  • tsmith652 Feb 01, 2009
    Thanks. I got the pump and replaced it in about an hour. Very easy fix.
  • 29 Answers
Posted on Jan 28, 2009
My washer wont do anything!
It could be the lid switch, i had similar problem, changed the switch, helped for a day, changed it again, same...So then i did a diagnostic test. it said that it was the main control board,changed it ($135), didn't help. I noticed that was a little bit of water on the floor under the shifter, changed that, worked for a while, then i noticed that it was wet again. I traced it to worn bearings that the tub spins on which wore the tub seal and made water leak on the shifter electrical connection, Changed the bearing which is the whole transmission and comes with new tub seals. It stopped the leak and has been working for more than a year.
Mar 24, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud Bang at End of Spin Cycle; Leak Underneath Washer
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak:
Check for tips on the link below to identify parts and removal:
Also check on the SEAL on the door and drum, it can also be worn out and reposition the drum to move out which can result in the noise when the spin is activated.
Jan 21, 2013 | Maytag Washing Machines
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet Frontloader Destroyed my home!!!!!!!!!
Are you kidding? You don't notice an odor or anything else other than a wet spot once that you thought your dog had an accident? Why is that Whirlpools fault? You have your due diligence to make sure if something is wet than there has to be a reason why something is wet. Besides, if you have that much black mold than there must have been some other signs of water than just that once.
Dec 15, 2007 | Whirlpool GHW9150 Front Load Washer
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
258 people viewed this question
Dan Webster
Dan Webster
Sal De
