Question about Mitsubishi Televison & Video
Remote control unite type KM058 is dead
When I change batteries and pres reset, screen is dead. I have changed again batteries with another ones, but the same result. Pleas advise what to do? BR, Tomas
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
  • 127 Answers
SOURCE: remote control not working (no functions),
Do the contacts look ok?
you can check if it is working by looking at it with a digital camera
press a button on the remote
if it shows as flashing on the digital camera screen, then you know it is transmitting.
then your problem would be either the device you are trying to operate is not receiving, or the remote is using the wrong code.
if the code is wrong then look it up online. there are some helpful sites that tell you the codes and how to program the remote.
good luck!
Posted on Jan 02, 2010
Testimonial: "Great help its pushed me in another direction"
  • 7 Answers
SOURCE: viewsonic remote RC00070P
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Posted on Aug 15, 2010
  • 11800 Answers
SOURCE: Casablanca Fan/Light Remote (Versa Touch #W-42)
This fan uses an RF /radio remote. To pick up the signals from the remote it must have an external antenna attached to the internal receiver - it's just a piece of wire. In your case this wire has been yanked out. You will have to open the fan, access the control box and see if the wire is still attached and in one piece - if not you will have to solder a new one in its place, a simple 10 minute job.
If you think that is too complicated then all you can do is to replace the entire control board. From here you can get the wiring, at the end.
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/VersaTouchCommonRep/W42-43Wallcontrols/VToneOperation.pdf
Posted on Feb 21, 2011
SOURCE: my samsung led remote control
There is a way to check whether the problem is with your remote or with the infrared sensor in your TV set.
If you have a digital camera (can also be your cell phone camera), it can be used as a kind of a "remote control tester" - although we cannot see the infrared bean emitted from the remotes, the CCD sensor inside the camera can!
If you aim your camera to the remote's extremity (the one that is pointed towards the TV set when you want to change a channel), as if you were going to take a picture of it and press a button in the remote control, you will see the remote's infrared LED blinking.
If you can see that, your remote is operating normally and maybe the sensor in the TV is blocked by an object that is in front of it, by a sticker someone glued in the TV's frame or it just got damaged by a power surge.
If you cannot see it blinking, your remote might be damaged and may need to be replaced.
Hope this info can help you!
Posted on Mar 12, 2011
Can't link my new lifestyle 48 remote control to my lifestyle 38 system?
If the remote does not work as you expect
If your system does not respond when you press a button on the remote, it could be time to
change batteries. For information on the type of batteries to use and how to change them,
refer to "Replacing the remote control batteries" on page 51
In some buildings, you may experience "dead spots" where the remote control will not
operate effectively. If this happens, move the remote a foot or two and try again. Also make
sure the cord that connects the power supply to the media center (and contains the remote
antenna) is stretched to its full length and is separated from other power cords. If these
efforts do not work, move the media center a few feet to a location where it provides a better
response.
If the batteries are fine and the suggestions concerning "dead spots," above do not work,
you may need an antenna extender. To contact Bose
customer service to request one, refer
to the address list included with the system.
Source
Dec 31, 2013 | Audio Players & Recorders
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
My Magic Remote stopped working
please reset the code again. and Proof.
if this do not resolve the problem do the following:
a) change the battery by new ones put the same type of battery and full charged.
b) clean the contacts battery with contacts cleaner
c) retight the spring contacts battery with pliers for a GOOD contacts
d) Open the r.control for clean the keypad swithc, for dirty, dust, open contacts or bad contacts test with VOM, Remember they send clean infrared beam from SYCOm micro trans to the receiver microcon.
e) Otherwise you must go to the repair shop TV for fix it
f) Proof again,.
God bless you
Aug 02, 2012 | LG AKB73295502 Remote Control GA935WJSA
Control
1) tight the springs contacts batteries with pliers, for better contacts.
2) clean the contacts batteries.
3) open the remote control and clean the Keypads from oxide, dust, and special spray contacts or alcohol.
4) Reset the code again, and try it. if the problem persist, go to the repair shop TV for fix it.
God bless you
Jun 20, 2012 | Toshiba Rem48tvb Remote Control
I replace my car battery and my kenwood dnx 7120 is now lock its asking for a 4 digit code
While code request mode,point the remote control to the unit and enter this code 55222277or 552222777(depending the remote contro you are using)(try to press the numbers that faster you can) that is way you type KCAR from the remote control.
you will not see any change on the screen while you entering the number,only when you enter the last number the unit will go to standby mode.
if you make a mistake,reset the unit and start all over again.
May 16, 2010 | Kenwood DNX7120 Car GPS Receiver
My remote is suddenly dead. I've changed the
remove the batteries. press any two buttons simultaneously for 2-3 minutes to reset the control. reinstall batteries and should work. this is in the owner's manual as well
Jun 08, 2009 | Samsung DVD-P181 DivX DVD Player
DVD recorder DMR EZ27EB
The remote control code is wrong. Change to the correct code. The batteries are depleted. Replace them with new ones. Point the remote control at the remote control sensor on the main unit. Remove obstacles between the remote ccontrol and the main unit. Remove dust from the transmission window and the unit's sensor. Colored glass may obstruct the signal reception/transmission. Don't place the signal sensor in direct sunlight or in areas that be subject to sun exposure. It may be necessary to set the code on the remote control again after changing the batteries. It may be necessary to set the manufacture code again after changing the batteries.
I hope this info can be of some help to you. Ms Tanya 2/12/08 4:02AM CST.
Jan 29, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Power off and on again and then no sound present
i assume pressing the source button on the remote control is how you normally turn it on again, (ie video FM CD etc)
it might be that moving the unit to the cabinite the battery power in the remote ( its not infra red its radio wave thay are not picked up by the fm antenna ) is insufficient to wake it up again,
change the batteries in the remote or try to see if there is some weird reason the cabinet is preventing these remote control radio waves from being recieved by the head unit, try opening the door and bring the remote within a few inches of the head unit and see if it turns on when you pres the cd button.
see how you go from there mate
Nov 30, 2007 | Bose Lifestyle 12 System
Televison & Video Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
