LG GS290 Cell Phone Logo
cokk Posted on Jan 23, 2013
Can not open the camera application and video as well as video recording or camera results also can not be opened
Anonymous
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 21 Answers
  • Posted on Jan 23, 2013
Anonymous
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
21
Questions
Helped
5637
Points
58
The camera software is defected so,we up to date the software...
1 Related Answer
Anonymous
  • 30 Answers
  • Posted on Aug 24, 2007
SOURCE: kg800 camera wont open
You can try to do a factory reset by pressing 2945#*# on your phone then going to factory reset but be advised that you will lose everything on your phone!
How to turn on web cam
Troubleshooting listed on the Toshiba website:
The TOSHIBA Web Camera Application provides you with convenient operations and easy access to:
  • Preview the video that the Web camera is currently capturing, at the same time
  • Support 2D mode, Shutter Glasses 3D mode and Red-Cyan Glasses 3D mode
  • Capture still images
  • Record videos
If this utility or feature is not installed on your computer, you can verify if it is available for your specific model under "Downloads" on the TOSHIBA support web site (support.toshiba.com). Not all utilities are available for every model and operating system. When installing any utilities, install the TOSHIBA Value Added Package first.
To open the Web Cam:
  1. Click the Start menu. On Windows 8, go to the Start screen.
  2. Enter "Camera" into the search field. On Windows 8, type "Camera" while viewing the Start screen.
  3. Click "Web Camera Application" in the search results.
  4. The Web Cam will open and live video from the camera will be displayed.
  5. When you place your cursor over the web cam video window a row of icons appear at the bottom.
Link to the Toshiba webpage referenced from above:
http://forums.toshiba.com/t5/General-Features-Knowledge-Base/TOSHIBA-Web-Camera-Utility/ta-p/346954
Cant get video on my camera
iPhone 3G doesnt support Video recording only for iPhone3GS and up.
Open your AppStore and purchase Application to record a Video
or Jailbreak your iDevice and download on the internet crack application like Qik_Video_Pro v5.0 ,VideoCamera-1.9 and others than install to your Phone.
I dont know how to turn camera on
Q: Camera Usage Instructions
A:
For use with systems including an Acer Orbicam, CrystalEye, or other factory installed camera.
Taking still pictures
  1. Double click the Orbicam Icon to start the program, which will open the main application screen.
  2. Set the configuration choices by clicking on the "gears" icon, which should open an additional window that slides out. Clickthe tabs and select the options for the desired settings. By default, still pictures will be sent to the "Pictures" folder.
  3. Set the resolution for still pictures by pressing the arrow under the main display. A drop down menu should appear with the available resolutions. Larger resolutions will result in larger file sizes.
  4. To take a picture, align the subject in front of the camera so that the display appears in the window as desired. Click Take Photo.
  5. The pictures should appear along the bottom of the application window if the Gallery view is enabled.
Recording video
  1. It is suggested to find a third party application to use this functionality.
Using the camera as a webcam
We cannot support third party application configuration or use.
I have toshiba a505, how do i mk my webcam work
A:
Recording video
1helpful
2answers
HD digital Camera as a webcam???
First install the software given along with your camera. Run remote shooting option. then 1.Download and Install Camtasia Studio. It allows to record a part of screen and broadcast it as a live stream to other applications like yahoo. Start Camtasia studio and select start a new project by recording screen. Click OK. 2.It will ask you what you want to record. In this dialog select Region of screen and click next. 3.Then you can select the viewfinder window of canon remote shooting. Click finish. It will open the recorder window. In the Tools->options> under the Live Tab select "Eanble Live output" and select the frames/sec. Click OK 4.In camstia record window click the record button 5.Launch your yahoo client and select mywebcam from the menu. Now you have a webcam available to you .
Hope tis helps. Rate this now!!
I carnt take photo on my webcam
Issue
Camera Usage Instructions Solution
Recording video
Re-install the Web Cam:
Close all open applications on your computer and make sure your power cord is plugged into the back of the notebook.
  1. Press ‘Alt + F10' to start eRecovery Management.
  2. Enter default password of 6 zero's. Example: 000000
    (Note: if this default password does not work, then a different password has taken its place. Acer is not responsible for any forgotten or misplaced passwords.)
  3. Select ‘Recovery Actions' and click ‘Next'
  4. Select ‘Reinstall Applications/drivers' and click ‘Next'
  5. On the left hand side of the newly opened window select the following: Windows XP
    ? Driver
    ?Camera
  6. On the right side of the same window, click ‘Install Camera Driver Now'
  7. The unit will reboot after the installation is complete
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Open in another application
Normal 0 This ptogram will eliminate your problem of the camera being busy or being used by another program. Really works great.
Double click on this site http://download.cnet.com/SplitCam/3000-2348_4-10500269.html
And then click on Download Now (3.5MB)
  1. Install Splitcam saying yes to everything during installation including the any warnings.
    2. Then run the Splitcam program by double clicking the downloaded program.
    3. Clicked on "Video" at the bottom right of the program window and selected your cmera.
Note: This will result in your camera being switched on and viewable in the
SplitCam program.
4. Opened up Skype (or other messengers) and go to "Tools" then "Options" then "Video settings."
5. Also setup your “Audio” while you are there.
6. Selected "SplitCam Capture" as my webcam, then click on save.
7. Webcam image will appeared in Skype or what ever messenger you are using.
Hope this Helps. Bud
2answers
Installing a video recording software with more recording time
try the application camcorder pro....unlimited video recording depending on the free memory of your memory card
Feb 16, 2008 • Nokia 3650
4answers
Acer Crystal Eye webcam
Import video is only when you have recorded a video using the webcam in a particular format and not on the fly which is what you are trying to do.
Record what you want using another application and the webcam then import the video into movie maker to edit.
Alternatively, I think you need to to go the options screen and select the default audio device. Go to control pannels and see if its there and then select the webcam as the default device for MS applications.
good luck
smeags
Problem with macally icecam
1. You can open only one video application at a time, therefore, you need to quit ALL the application first, then open the one application you want to use. such as YIM or Skype.
2. Please open the iceCam Monitor, go to Monitor tab, check the "Record Video" and select "Record Until MouseClick".
A new Save window will pop up, set up the filename and location and click SAVE button.
Once you click the mouse button, it will save the recorded video as QuickTime Movie clip format file on the selected location.
If you want a picture, you could run the video and pause it and make a screen shot to grab the picture from the video.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
