Question about SIIG USB SoundWave 7.1
Sigg usb souwave 7.1 driver wont install - SIIG USB SoundWave 7.1
Ua 101 driver won't install on windows 7 64 bit
Officially Microsoft says that 32bit drivers are not supported on a 64bit system. Check hardware manufacture for updated drivers. Good luck.
Aug 31, 2012 | Edirol UA-101 External Sound System
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
Driver wont install from cd windows 7
Download the compatible drivers (Works with Windows 2000 / XP / Vista / Win 7 32bit ) @ http://easycapexpertti.mybisi.com/product/easycap-dc60-v21c-usb-20-video-capture-xp-vista
Hope it helps
Jul 30, 2010 | Ulead Videostudio 8 for PC
Problem with a Toshiba Satelite L45 s7423 Model my os is Windows 7. I recently got this laptop as a present from a friend since he formated it.....when I got it everything worked except the ethernet cable...
windows 7 automatically install all the drivers in case it had missed the driver kindly download the driver from friend system or internet cafe on your usb drive.
there is link to download drivers for Ethernet.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
once your your online go to computer management > drivers and right click on WIFI card and click on update drivers it will download the drivers and install the drivers.
Jun 07, 2010 | Computers & Internet
Bluetooth usb micro adapter not working
Check out http://www.sevenforums.com/hardware-devices/156598-bluetooth-initial-configuration-will-not-launch.html
finally I found a solution that worked
May 17, 2010 | IOGear Bluetooth 20 USB Micro Adapter...
Memory Card
Do you have the driver utility cd for your card? try installing the driver from that even if it is not a windows 7 driver. You can always get an external card reader with usb interface if all fails.
Sep 02, 2009 | SanDisk 4GB microSDHC Memory Card
Pcstudio 7 wont download on my laptop
Have you got pcstudio 3 on your laptop? If so remove all Samsung studios. Download the latest pcstudio 7 from Samsung plus USB driver. Put the USB driver on FIRST followed by pcstudio7 then it should work.
Mar 23, 2009 | Samsung SGH-i8510 INNOV8 Cell Phone
Hello,usb.2.0-ser can't install in vista window, thanks
r u using 64-bit because vista 64-bit wont allow drivers that are not whql certified to install...
Nov 28, 2008 | Computers & Internet
SIIG USB SoundWave 7.1 Logo
22 people viewed this question
Top SIIG Computers & Internet Experts
k24674
PC Tech101
Level 1 Expert
tony wahlman
tony wahlman
Are you a SIIG Computer and Internet Expert? Answer questions, earn points and help others
