Question about Microsoft VISTA Computers & Internet
Can not update windows error wcode 800FO203 - VISTA Microsoft Computers & Internet
How Do I Fix Windows 10 Store Error Code 0x80072EFD?
The store error code 0x80072EFD might be displayed for several reasons. There are detailed solutions proposed in the link below. Have a look.
https://appuals.com/how-to-fix-windows-10-store-error-code-0x80072efd/
Feb 23, 2018 | Computers & Internet
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
Hi my mum has just purchased windows 8..can get onto facebook...but when she wants to play mindjolt games..(golf solitaire) it will come on... but then has a white screen where the game should be.altho it...
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this: Install the Windows 8.1 Update (KB 2919355)
  • ?Email
  • Microsoft support. Code 0x800F0922 This error might mean that a file needed by Windows Update is damaged or missing. Here are a few steps you can try to fix the problem:
    1. Run the Windows 8.1 Update troubleshooter to fix the problem.
    2. Install the Windows 8.1 Update or Windows RT 8.1 Update.
    Code 0x800F0923 This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support. Code 0x800F0922 This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
    The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition. Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
    Error: Failure configuring Windows Updates. Reverting changes. These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
    You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
    To view your update history:
    1. Open Windows Update by swiping in from the right edge of the screen (or, if you're using a mouse, pointing to the lower-right corner of the screen and moving the mouse pointer up), tapping or clicking Settings, tapping or clicking Change PC settings, and then tapping or clicking Update and recovery.
    2. Tap or click View your update history.
    Error: The update is not applicable to your computer. This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
    To refresh you PC:
    1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings. (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click Settings, and then click Change PC settings.)
    2. Tap or click Update and recovery, and then tap or click Recovery.
    3. Under Refresh your PC without affecting your files, tap or click Get started.
    4. Follow the instructions on the screen.
May 07, 2017 | Computers & Internet
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Windows Update error code 80070103
This windows update error code means you already have the latest drivers installed onto your computer and you don't really need to upgrade it.
To know more, follow this link: Windows Update error code 80070103
or you can also visit: Update error Code 80070103
Hope this helps, Mrityunjay.
Jun 16, 2012 | Computers & Internet
After formating; i get error 800b0100 at the 39 minute of setup. This occurred 6 times. I did a complete format 3 times and quick format 3 times
Windows Update Error 800B0100
If you receive the Windows Update error 800b0100, it means that a file needed by Windows Update is not registered with Windows correctly. The System Update Readiness Tool can correct some conditions that cause this error. To use the tool, follow these steps:
  1. Go to the System Update Readiness Tool webpage. In the Information for advanced users section, find the version of Windows and system type of your computer, and then click the link to download the System Update Readiness Tool. If you don't know which version of Windows you have, see View your computer information.
  2. Run Windows Update again.
    gl_ico.png Note Typically, the scan takes 15 minutes or less, but it can take longer on some computers. The Windows Update progress bar is not updated during the scan, and progress seems to stop at 60% complete for some time. This behavior is expected. The scan is still running and you should not cancel the update.
Jun 09, 2010 | Microsoft Windows XP Professional
NEW T/W CODES 27/12/2009
00 CF 53 OC 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
this works for me in north west
Dec 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
Fixing error number for windows xp
If you tried exiting Windows Update, waiting 10 to 15 minutes, and then starting Windows Update again, or if you allowed Windows Automatic Updates to install updates during its 24-hour time cycle, and the error message still persists,
Other methods to solve issue:
Click Here
Sep 14, 2008 | Computers & Internet
Windows update error 80240016
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
Jun 17, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft updates
Most of the time when updates cannot be installed, is because you have installed a file that is newer than the one provided by Microsoft, or you already have the "update" and Microsoft gives you the error.
Essentially when your computer communicates with the Windows Update website. It uses TWO technologies called:
Active X - to interact with the Microsoft site. The first time you visit the Update website, using your profile, you are asked if you will accept the Windows Update Control Package (the Active X control) onto your machine.
SSL (Secure Socket Layer) - A method of data encryption used by Internet Explorer.
Now this general error message 0x800A138F, that some folks get when they visit Windows Update, has been around for a while. BUT, when the MSBlast virus was unleashed Microsoft changed a few things at the main update website. One of them was to use Akamai for additional bandwidth and this connectivity is exclusively using HTTPS (SSL) for the downloading of the update catalogue. It is since then that we have seen an escalation in the number of 0x800A138F error messages!
The following steps will help many of you... BUT
What would be REALLY helpful to anyone trying to support you, is if you go to the "Windows Update Log" and look for any "Errors". This gives a clearer indication as to the exact nature of the problem. (The 0x800A138F error message is a "General" error THE real error number is in the log. A list of possible error messages is in a table at the bottom of this page.)
The windows update log is in the following places:
C:\Windows\Windows Update.log (Win XP & Win98/Me)
C:\WINNT\Windows Update.log (Windows 2000)
Just copy and paste the above in Windows Explorer to open the log file...
Feb 26, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
