Question about Casio Watches
Casio pad2 drivers
Not find drivers
Casio prt 41
If you have that kind of problem with your Casio Watch, there are 2 possible problems here:
-Battery is leak
-They did not reset the watch properly if the battery was replaced.
Best you can do is take it to an official Casio dealer, they will handle your Casio watch properly.
You can find any spare you need for your Casio in our website. At TicTacArea.com we are official Casio dealers and we will be glad to help you with this and any other problem you may find related to your Casio Watch. Casio Watches Casio Multi Task Gear Watches
Apr 10, 2014 | Casio Watches
My casio watch say close on the face
Can you send a picture of the face and the reference of your Casio Watch?.
At TicTacArea.com we can help you out with any Casio watch related problem. We are Casio watches official dealers. Casio Shock Watches
Apr 09, 2014 | Watches
How do i shorten the band on my casio 3319
You look for the end of the link that has a screw like notch and tap it out with a small screw driver (like a eyeglass screwdriver or any thing you can sub,) and pull out with a needle nose pliers. Be careful and out the band on a rubber or paper surface though.
Providing you have the tools. I did mine in 3 min.
Oct 17, 2009 | Casio Watches
I cannot find a manual for my Casio 384 AW-20 watch.
If you go the goolgle and type in Casio Watch Manuals, it should direct you to the proper webpage for Casio Watch Manuals. The website asks for a 4-digit code, which is imprinted on the back cover of Casio Watches and surrounded by a box. If your watch does not have the 4-digit code surrounded by a box, it may be older than the website supports.
Feb 18, 2009 | Casio Watches
3747 Replacement Watch Band
Use this link to get in touch with Casio:
http://www.casio.com/home/
Choose relevant application under the SUPPORT. Here you can find Technical Support, Casio Parts etc.
Choose your nearest region and ask to supply new watch band.
Do not forget to rate, please.
Jan 13, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do you replace the watch band on a casio g-shock
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
Jul 20, 2008 | Casio Watches
Casio watch, removal of links
I clipped a driver pin out of a safety pin and tapped the band pins out with the driver pin and a hammer. It helps to have someone hold the band on a hard place over a hole.
geb
Dec 07, 2007 | Casio Marine Gear AMW320D9EV Wrist Watch
Watches Logo
44 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
