Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
Toshiba 51h83 in. rear projection tv has no picture and sound but when i turn on the tv it makes a clicking noise. does anyone have a solution?
I've changed the convergence board and with little luck, the pic was getting more distorted. now i have no picture and no sound, but when i turn on the tv now all i does is make a clicking noise like it's trying to turn on. does anyone have a solution?
  • bigdaddya25 Aug 31, 2008
    bigscreen has no picture, but has sound, and is making a clicking sound
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
You may have a new defective conv. board?
Posted on Oct 19, 2007
SOURCE:
Color distortion, hazy snowy screen with thin red lines, suddenly happened had perfect pic 24 hours ago
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi VS-50705 50" Rear Projection...
Distorted Screen
This tv have a problem call convergence.The convergence board require to change 2 STK convergence ICS and some or all it resistors.U have soldering iron tools and solders?U know how to solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 27, 2010 | RCA R52WH73 Projection Television
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
Tv pic has redbluegreen images pic distorted
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs or defective ICs. If you feel that you want to attempt the repair yourself, please update this with that indication and additional details and instructions will follow. The parts for this repair will run about $40-$60.
Dan
Dec 10, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Rolling and distorted picture
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 02, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Convergence board
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Oct 21, 2008 | Toshiba 43H71 43" Rear Projection...
Convergence problem
The convergence ICs are located on the left board on a huge heatsink they should be STK392-110 or STK392-120. You can get replacement ICs at the following link and they also provide free step by step instructions on how to remove and install the new ICs.
http://servicemanuals.vstore.ca/
Mar 29, 2008 | Philips 60PP9202 60" Rear Projection...
Akai PT4298HD problemo
I'm not a repair guy, just happen to have one of these TV's. Seems to me that unplugging the Convergence Board removes it from the equation and suggests something else might be the problem. I got most of my help from here and also from this thread:
http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/Samsung_42_Convergence_problem_P4569/
The samsung TV is the same TV as this Akai, it's just a rebadged Samsung.
One important difference in my TV from yours. I did have a timer light, and with the back off, I could hear it power up when I plugged it in and turned it on. The timer light would flash then it would go off.
When I removed the convergence board, I could clearly see burn marks on the bottom of the board where one of the amps was soldered on. That gave me some piece of mind in ordering the part. I just scanned that other thread but remember some people talking about the power supply failing as well as the main board, you might pursue those avenues.
I wish you luck in fixing this!
Mar 15, 2008 | Akai PT4298HD Rear Projection Television
Pic distorted slightly on left side. news (crawl) on bottom of screen angles down on left side, top of pic seems to angle up also. very minor problem but annoying anyway! pic clarity & color excellent.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Toshiba 55H70 55" Rear Projection...
Hitaci 53 rear projection
ohhh boy very carefully, i released the wires from around the holders to give me room and disconnected the ones that didn't stretch enough then removed the screws around the black holder that holds the boards and lifted the board up and unsolded the head sink and then the ic's
check out these liks for pics and better explainantion
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Dec 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
551 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
