I have a DVD micro theatre model no mcd388 the Main Unit has stopped working. The main unit has no power. There is power in the wireless subwoofer . Please advice.
SOURCE: Can't get sound from the wireless subwoofer
I had the same problem and it turned out that the directions are very unclear. You need to not only press the ID/SET button on the wireless system, but also on the wireless subwoofer itself. That solved my problem.
Posted on Oct 04, 2007
SOURCE: No power to main unit
this is easy       either bad cord or bad internal power supply.
Posted on Oct 24, 2007
Benimur
  • 6966 Answers
SOURCE: DVD PLAYER MODEL, SD-K740SU
For a Toshiba SDK740SU, to remove a stuck disc:
1. Remove the top and front cabinet cover;
2. once exposed, slide/move the Rack Loading (white) towards the right with a sturdy instrument such as a common screwdriver;
3. draw the tray out
Please refer to image below:
The only possible easy user workable reset is to unplug the unit for quite some time.
Should the above be not corrective, pls post back whether you have the 740SU or the 740SUA version.
Hope this be of some help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 11, 2008
  • 10 Answers
SOURCE: Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
Posted on Apr 05, 2008
timtrent
  • 3 Answers
SOURCE: durabrand dual 7c dvd replacement screen
I have two slave screens for sale. If you need one let me know. They are both slaves but if you have a cracked screen on the main unit, you can very easily pull out the screen on a slave and install the LCD screen into the main unit as they are both the same. Most all models are completely interchangeable. No wires to solder, just three plug-in wires. Both slave units work great, garanteed. $40 + shipping (ea). Paypal accepted. timtrentb (at) hotmail. com.
Posted on Jul 03, 2008
Panasonic_sc_pt_170_displaying_locked
This unit has two locks for demonstration purposes so discs can't be stolen.
Eject lock:
With the unit powered on, press and hold stop button and power button on main unit for at least three seconds until it shows unlocked.
Function lock:
With the unit powered on, press and hold play button and power button on main unit for at least three seconds until it shows unlocked.
Hope this helps.
May 28, 2011 | Panasonic SC-PT160 Home Theatre Kit
I have a se-fx65 wireless system but the remote surrond sound unit will not pick up a signal from the main unit i have checked that the card in the back of the main unit is in properly and the right way...
Thankyou for your response! our SE-FX65 had been out of commission for over 2 years (we'd just given up on it) and I tried your solution as a last-ditch before the wireless unit hit the garage sale box. The key was pushing the >>/>> button on the HOME THEATRE UNIT, not on the remote.
So hit >>/>> on home theatre, 3 on the remote,
look for the P, then the wireless unit turns green
(the SET/ID is on back of wireless if you need that for multiple units) and THEN
hit the >>/>> and 3 again to finish the job.
Thanks again for the suggestion. I am doing the happy dance!
Jan 01, 2011 | Panasonic Home Theater System System
Philips DC912/37 will not pair with the subwoofer. I have had the device for 2 years, and the subwoofer stopped working recently, and now it will not pair with the tuner.
This worked for me. Try it and it should work for you all as well..;-)
Frequently asked questions See all FAQs Question How do I get the main unit to recognize the subwoofer? Answer Wireless connection will set up automatically when you switch on both the main unit and subwoofer.
Sometimes you may encounter the problem that the main unit does not recognize the subwoofer. Try the following process to solve the problem:
  • They are heavily interfered by other wireless home appliance such wireless network, TV etc. Move the subwoofer to another place, the main unit will auto detect & recognize it.
  • Switch off the main unit and the subwoofer and then switch on them again. The main unit should recognize the subwoofer automatically.
If neither of the above works, try to pair with them manually.
  1. In standby mode, press and hold the 090518075138_27245.gif button on the main unit (PAIR flashes on the display screen.) to activate signal transmitting.
  2. Press and hold the PAIR button on the rear of the subwoofer (You will find the LED indicator on the subwoofer flashes in blue and green alternatively) to activate signal receiving.
The wireless connection will set up automatically and the main unit should recognize the subwoofer now.
Dec 21, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
How can i pair my subwoofer to the main unit
Oct 13, 2010 | Philips DC912/37 iPod Docking Shelf Bar...
Kef instant theatre - kit200
Nice player. I'm not lucky enough to own one myself, but I found this info which might be worth a try:
Kef Kit 100 & Kef Kit 200 Instant DVD Theatre handset hacks 1. Press & hold the "Skip Back" button, "Play" button & "Volume Up" button on the main unit.
2. After a few seconds the front display should display "PAL RESET"
3. Release the "keys.
4. Power off your unit at the mains.
5. After 20 seconds, power on your DVD player, thats it!
Oct 27, 2008 | KEF Audio KIT100 System
Problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
Oct 19, 2008 | Samsung SWA-4000
Feb 24, 2008 | Panasonic SC-HT730 System
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
