Question about Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV
WILL NOT STAY TURN ON
I WILL TURN OFF THE T.V. AND THEN TURN IT BACK ON. IT LL SHUT DOWN & BLINK TEN TIMES. IT HAS TO STAY OFF FOR AT LEAST 12HOURS BEFORE THE T.V. REAMAINS ON
  • 10,594 Answers
Its bit complicated problem. Service manual states HV Protection as 10 times blinks.
You need to replace D Board or if you know basic electronics and familiar with TV repair, then check followings..
• Q8014 or Q8013 have shorted replace
along with R8051 on D Board
• IC8005 is damaged (D Board
Hope this info will help you out.
Posted on Jan 30, 2009
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
I have a WD-65737. The lamp gave out, so I replaced it. Now it will start, but generally after about 5 minutes of it running fine, it'll shut down and blink yellow
Where did you get the bulb. I tried a cheap one and it did not work correctly. I found a bulb dealer that had I believe had a warrentee of a year and I have had no problem since. I have a WD73737. the cheap bulb carrage was not quite to specs and did not fit correctly from bulb surface and there was a gap and color kept changing on screen. I got the bulb cheaper than Mitsubishi, aprox 75 t0 80dollars.
Sep 01, 2017 | Televison & Video
When I turn the power on, it clicks on then off, the power will not stay on. I do not have the manual
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 29, 2011 | Mitsubishi WS-55511 55" Rear Projection...
When I attempt to turn on the TV the green power light will stay on for about 2 seconds. Did system reset with paperclip, timer light flashed for 1 minute. Tried again with same result.
STANDARD ANSWER FOR THIS PROBLEM:
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
BEFORE YOU RATE THIS INFORMATION LET ME KNOW WHAT YOU FIND, i AM HERE TOP HELP.
SD TECH
Jul 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
My tv looks fine than sometime it will just shut off, and I will have to wait to turn it back on and it my stay on for 2 day and not shut off
Samsung HL-R6167w standby light blink do not power up sometime it would come on and work then it shut down the fan spin with a noise when press remote the green power light flashes.
Jul 21, 2010 | Hitachi 50UX57B 50" Rear Projection...
Viewsonic model vs10846-1m aka N4060W won't turn on.
I found if you hold the power button down on the remote or the tv , hold it down for anywhere from 2-5 minutes the green light will blink and blink and blink, all of the sudden it will stay on. then shut off, but if you turn it back on on the light will again stay on , do this 3-4 times and then the tv will turn on. Once you turn it off for over 10 minutes you will have to go through the whole rigamaroo again. This will only work for a while, mine has quit completely now. The Veiwsonic guy gave me a part number for a power board he said was most liley the issue. It ran about $71. I've got a repairman coming tomorrow to see what the dealio is. I'll let you know what he tells me, good luck!
Jan 28, 2009 | Televison & Video
Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV Logo
529 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
