Question about Canon PIXMA MX895 Inkjet Multifunction Printer - Colour - Photo Print
Unable to fix a Paper jam in canon mx895. Can you help?
Paper jam corrected but paper still catching Appears to be on the under carriage of the of the cartridge carriage.
SOURCE: paper jam light constantly on.
The suggestion with the heavy stock paper worked. I used a vanilla folder but this was not heavy enough so I simply folded it in half. I had the problem where it would feed 1 sheet of paper in the auto sheet feeder upon starting the printer up. This is unusual in itself. The single sheet of paper would go through normally. But with the vanilla folder, as it was going through, I heard a loud sound like a contraption somewhere was being reset or dislodged or relodged or relocated from some stuck position. After the sound, the green light came on no problem and it all worked. Try something not so heavy like a vanilla folder that has been trimmed down. Then fold it. You might have to hold it up against the black roller wheel to get it to engage the roller wheel when you turn the printer on. Hope this helps.
Posted on Aug 25, 2007
SOURCE: I have a Canon Pixma
It was covered by Staples Extended warrantee and they exchanged it.
Posted on Nov 15, 2008
  • 684 Answers
SOURCE: pper jams
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
Posted on May 27, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 199 Answers
SOURCE: Canon ip1800 will not feed paper...One side jams
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Posted on Jun 25, 2009
Does not print. How can I eliminate recurrent 6A81 error?
Error 6A81 appears on Canon printers like Pixma IP4800, MG5140, MG5150, MX882...
Solution 1: This is a purge unit error.
  • There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly.
  • Try to move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit.
  • There maybe crumpled paper jammed in the purge.
  • If all looks well, the purge unit may be defective and had to be replaced.
Solution 2:
  • The wiper on the purge may have stuck. It slides back and forth and they have been known to stick.
  • Push it with a long screwdriver to see if it moves.
Solution 3:
  • Something is blocking the printer inside. It could be a paper jam or a foreign object.
  • Check using a flashlight, to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen.
  • If there is nothing obvious, unplug the printer power supply.
Solution 3a ( thanks to Peter van eijden for the tip):
  • Printer off.
  • Bring by hand the ink-carrier to the right side.
  • Push down carefully on the carrier, hold on and shalter the printer: push the left site of the carrier down, because its will come up.
Solution 4:
  • Take a dry cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Solution 5:
  • Hold the printer in both hands (you may need another person to help you), turn it upside down and shake it for a few seconds to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
  • Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Then try to form feed again. If that works, then try to print again.
courtesy fix-your-printer.blogspot
Mar 15, 2016 | Canon PIXMA MG5320 All-in-One Printer
Printer gets confused. Shows on screen an error code 5100 But I have no idea what that means and dont have a reference manual telling me what it is or where to try to get a correction. Any help is...
Hi
Error 5100 is carriage error. Carriage is printer's cartridge holder. This means that there is some problem with printer's carriage, you'll need to check the plastic stick (around 1/4" wide). Also, check for any obstructions in the printer's carrriage path ( like small bits of paper stuck under carriage or any kind of paper jam).
Turn off the printer and remove the cartridges and reseat them after cleaning the carriage's bottom area with a Q-tip.
Please get back to me in case of any queries.
Daniel Scott
Jun 24, 2010 | Canon Pixma MP800 All-In-One InkJet...
Error 6A00 appears. Will not print. Cannot find
Try it maybe
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
MP830 6A00 error & ON/OFF switch not working
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 6A00 error, On switch also wont work
Hi
Seen this lots
Solution 1:
Solution 2:
Solution 3:
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
E3 paper jam
if the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Apr 21, 2008 | Office Equipment & Supplies
PAPER JAM
Hi, oh dear, you have a paper jam in or near the roller or very small one in carriage. Open up unit as if rplacing cartridges, get a torch if you have to and search for tiny jam. A good clue, is does the carriage return to correct positon upon opening?
Jan 16, 2008 | Lexmark X6170 All-In-One InkJet Printer
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
Canon PIXMA MX895 Inkjet Multifunction Printer - Colour - Photo Print Logo
129 people viewed this question
old marine
old marine
