Question about Canon PIXMA MX895 Inkjet Multifunction Printer - Colour - Photo Print
Paper jam in canon mx895
Paper jam corrected but paper still catching Appears to be on the under carriage of the of the cartridge carriage
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
  • 52 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Posted on Jan 23, 2009
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
SOURCE: Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
Posted on Jun 18, 2009
  • 199 Answers
SOURCE: Canon ip1800 will not feed paper...One side jams
canon has a friction feed system,
clear the paper path and check if there are any small paper peace,
clean the pickup roller by a waterized cloth,
proper set the paper guide and try print again.
Posted on Jun 25, 2009
Cartridge Carrier is Blocked
Check the all-in-one product for paper jams and reset the paper feed motors.
Normally the cause of these errors is a piece of paper or other material in the paper path. Sometimes the paper feed assembly has become unsynchronized. Use the following steps to correct these issues:
1: With the all-in-one turned on and ready, open the ink-cartridge access door. The ink cartridges come to an access point if the carriage can move.
2: Unplug the black power cord from the back of the product. The power plug must be pulled out to resynchronize the paper feed and carriage motors. Simply turning the product off does not work.
3. Remove both ink cartridges and lower the ink cartridge latches, as shown in the figure below, so that they do not catch on the product frame when the product reinitializes. Do not close the ink-cartridge access door at this time.
4: Remove the remaining print media from the paper supply tray. Discard any pieces of media that are damaged.
5. Unlock and remove the rear access door.
6. Being very careful, slowly and gently pull any jammed media out of the product through the rear access door.
7: Make sure that no jammed media remains in the product. Be sure to check inside of the product on the sides to verify that media did crumple into these areas.
8: Reinsert and lock the rear access door. Make sure that the door locks fully. The paper can skew if the rear access door is not fully locked.
9. Close the ink-cartridge access door. 10. Plug the power cord into the back of the product. If the product does not automatically turn on, press ON. Let the product initialize until a front panel message appears, requesting ink cartridges. If the carriage cannot move, remove the power cable again and determine what the carriage is caught on. Manually move the carriage to free it from whatever has blocked, it and then repeat this step. 11: Open the product and reinsert the ink cartridges. 12. Reload the input tray with print media and try printing again. The media must be loaded properly for it to feed correctly. It must be fully inserted into the product but not to the point that it bows from the pressure. 13. The HP all-in-one product will request that an alignment be performed after closing the ink-cartridge access door. Perform the alignment. The HP all-in-one product should be fully functional when the alignment is complete. It might be necessary to repeat the process more than once if the product was completely out of synchronization. Clean the paper rollers If the issue persists after checking the paper path and resetting the all-in-one product, follow these steps: 1. With the product on, open the ink-cartridge access door. The ink cartridges come to an access point if the carriage can move. 2. Unplug the black power cord from the back of the product. With the power cord unplugged, the print carriage (the part that the ink cartridges are in) can be moved. 3. Locate the four small, metal paper rollers (not the rubber rollers) and the carriage rod as shown in the figure below. The carriage rod is the large metal rod that the print carriage rides on. If these rods are not bright and shiny or if they have buildup on them, they should be cleaned. 4. Use a soft, lint-free cloth lightly moistened with water (distilled water preferred) to clean the rollers and the carriage rod. With the power cord unplugged, print carriage should move back and forth freely so that all parts can be cleaned 5. Open the rear access door. Use a soft, lint-free cloth lightly moistened with water (distilled water preferred) to clean the three rollers that are shown in the figure below. Close the rear access door when the cleaning is finished. 6. Close the all-in-one product and reconnect the power cord. Try printing again to see if the issue is corrected Hope this should fix the problem Good luck.............
Aug 02, 2010 | HP OfficeJet Pro 1170c InkJet Printer
Printer gets confused. Shows on screen an error code 5100 But I have no idea what that means and dont have a reference manual telling me what it is or where to try to get a correction. Any help is...
Hi
Error 5100 is carriage error. Carriage is printer's cartridge holder. This means that there is some problem with printer's carriage, you'll need to check the plastic stick (around 1/4" wide). Also, check for any obstructions in the printer's carrriage path ( like small bits of paper stuck under carriage or any kind of paper jam).
Turn off the printer and remove the cartridges and reseat them after cleaning the carriage's bottom area with a Q-tip.
Please get back to me in case of any queries.
Daniel Scott
Jun 24, 2010 | Canon Pixma MP800 All-In-One InkJet...
How do i clear a cartridge jam on my hp all in one printer
Is the paper feeding crooked and catching on the carriage? If so, remove the rear access door and clean the feed rollers with a damp cloth.
some other resion is The print carriage is the part that holds the print cartridges. Carriage blocked or jammed messages may occur for these reasons:
A paper jam was cleared from the front instead of the back on models that have a rear access door.
The print cartridges were installed incorrectly.
There is some obstruction in the path of the print carriage.
Open the print cartridge access door of the all-in-one so that the print carriage can be accessed.
Thanks,
Dec 03, 2009 | Computers & Internet
Error message carriage jam and/or paper jam
Often a carriage jam is caused by a paper jam. If you're getting a carriage jam message and a paper jam message, this video should help.
utube.png You-Tube video "wPjahOY5CDo" placeholder
Nov 21, 2009 | HP Photosmart C6380 All-In-One InkJet...
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Dell 946 -carriage jam/stalled
the ink carriage is in far left position and jammed. it appears that the black cartridge far left was not seated correctly. how do i resolve this?
Nov 19, 2008 | Dell 946 All-In-One InkJet Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Paper Jam
Causes of repeated paper jams If paper jams occur repeatedly, one of the following may be causing them: The paper is being pushed in too far. The paper should only be pushed in until the first resistance. Continuing to push the paper in will force the paper up into the paper rollers and will cause the printer to pull in multiple pages. Obstructions in the paper path. Open the all-in-one (front and back) and check for obstructions.
  • Unlocked rear access door. Follow the steps above to install the rear access door correctly (see Figure 3). If this condition is present, the paper will skew in the all-in-one.
  • The paper guides are not positioned against the paper. Adjust the paper length and width guides so they fit snugly against the paper.
  • Incorrect paper. The paper should be flat and smooth with no folded, torn, or rough edges. Papers with a glossy finish and coated papers may not feed into the unit correctly. Paper that has already been printed on once can also cause problems.
  • Partially installed paper tray. The paper tray must be inserted all of the way into the all-in-one.
  • Dirty paper feed rollers. Over time paper fibers and dust will stick to the rollers and should be removed.. Also verify that the rollers on the rear access door are clean and turn freely.
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If it pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism
May 21, 2008 | Office Equipment & Supplies
PAPER JAM
Hi, oh dear, you have a paper jam in or near the roller or very small one in carriage. Open up unit as if rplacing cartridges, get a torch if you have to and search for tiny jam. A good clue, is does the carriage return to correct positon upon opening?
Jan 16, 2008 | Lexmark X6170 All-In-One InkJet Printer
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
Canon PIXMA MX895 Inkjet Multifunction Printer - Colour - Photo Print Logo
136 people viewed this question
old marine
old marine
