Question about True Technogym Excite Run 700 Treadmill
DSTV settings on excite700
I have a technogym excite run as well as the cycle, arm elliptical and stepper. They are conneted to the DSTV in the buidling, but I cant seem to get them to put the correct channel onto channel one or for them to show the dstv while they are on idle. i know how to scan for the channels and save the data, but I want the dstv channel to be channel 1 and for it to show during idle. Thanks
Technogym run excite 700 shows COM error equipment blocked
There is a fan in the iron box. You have to change them. 2 fans required. Change both.
Feb 04, 2016 | True Technogym Excite Run 700 Treadmill
Technogym cross trainer - equipment is blocked 16
Equipment is blocked is unfortunately a common 'error' that shows up with Technogym, but it refers to a number of errors.
-Does your emergency stop swivel a lot, or is it fixed? If a cable has come off inside, that can be the cause.
-A loose cable running up the arm of the frame is the next thing to look at.
-Lastly, and most common is the motor controller has fried. It's a common thing with Technogym, and is an expensive repair. Technogym will tell you that you have to replace it, but since it's electronics it can be repaired, as long as someone knows what they are doing.
Where are you located?
Apr 20, 2014 | True Technogym Excite Run 700 Treadmill
Speed setting
stopschalter ist defekt oder unten an der box ist ein kabel nicht richtig drin!
Feb 02, 2014 | True Technogym Excite Run 700 Treadmill
Treadmill display problem
The equipment is blocked... (2) this is the message I get in my Run excite 700 technogym treadmill.
Can some one help.
Thanks a lot
Jan 08, 2014 | True Technogym Excite Run 700 Treadmill
Technogym excite 700
open the MENU, and follow the steps indicated for tune.
Otherwise you must read your owner manual or download free from
www.fitness.manualsonline.com
God bless you
Jun 18, 2013 | Exercise & Fitness
Technogym Run Excite 700 Schematics
Dear John
Please find here in attachment the schematics for the lower kit/board for the Technogym Run Excite Treadmills.
We would be very happy to help you. So, can you please tell us where do you come from? We will put you in contact with our local customer care.
Thanks
Technogym Staff
Apr 13, 2013 | True Technogym Excite Run 700 Treadmill
True Technogym Excite Run 700 Treadmill Logo
Top True Exercise & Fitness Experts
Tom Chichester
Electro Med Services...
Are you a True Exercise and Fitnes Expert? Answer questions, earn points and help others
