Question about Samsung Washing Machines
Samsung SW75V9W spin - Samsung Washing Machines
  • Samsung Master
  • 17,130 Answers
Please be specific, if there is no spin check the motor and voltage when the spin cycle starts, if there is no voltage then the controller is a suspect.
If the spin RPM is low then check the drive and reset for easing the friction.
Click on : bearings
Posted on Jan 23, 2013
My samsung washing machine WA40J3000A is not spinning. Everything else works but it does not spin during wash, rinse or spin cycle.
if you can hear the motor running on spin or rinse then the clutch is not working if you cannot hear the motor then the motor is not working.
Feb 28, 2018 | Samsung Washing Machines
Samsung toploader,WA13U7 does not pump or spin. When manually put on spin only, only the bottom plate spins and not the sides of the drum
firstly if it has water in it at the spin cycle it wont spin,water remaining is due to a blocked or faulty pump it doesnt take much to jam them
Jan 21, 2018 | Samsung Washing Machines
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
it it is not slapping in when it goes to spin , it will not spin
Dec 18, 2015 | Samsung Washing Machines
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Samsung HLS5687WX/XAA color wheel not spinning. It is "twitching" and acting like it wants to spin, but will not. Moves when I do it by hand, but has a slight squeaking sound.
If I were you I would grab 1 of these needle oilers. Put a tiny bit where it spins as it may now be binding and not able to move. Be careful not to get onto any electrical components or the wheel itself.
Nov 27, 2012 | Samsung DLP HL-P5663W 56" TV
I have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
i have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
Sep 21, 2010 | Washing Machines
Samsung, rossby washing machine
There is a capacitor linked to your motor by wiring.. That capacitor is most likely the fault... It is normally a 400vac 12UF(J) capacitor
Jul 10, 2008 | Samsung Washing Machines
Washing Machines Logo
190 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
