Can I convert a Rinnai Flame Fire Inbuilt Royale IB35R running on natural gas to LPG? THANKS
2 Suggested Answers
  • 120 Answers
SOURCE: does not want to start
Intermittent faults on these units are very very rare; they either work or they dont! Ive had similar reports that ended up being more of a gas regulator fault (thats the hunk of metal that the small copper tubes from the cylinders are connected to). Do you have any other applainces on gas. When the heater doesnt work try the others'; if they work keep thenm going and then go back and try the heater. Does the heater try and ignite? I also like to recomend getting these heaters serviced occasionally. Just like cars, intermittent faults can be a reminder to get a good service done.
Posted on Jul 21, 2010
I have a rinnai flame fire inbuilt royale 1b35etr but not igniting . what do i do. electrics come on and no smell of gas- pipes all look good and gas bottle on
First, be sure that the inline gas shut off valve is turned ON. The gas tank valve is On, but the inline valve may not be. if you do find that the inline gas gas shut off valve is ON, there may be air in the gas line that needs to purged.
In case you have your Owner's Manual, I have included a link to it, that you can download & print for future reference. it will explain how to purge the line, if necessary.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Flames/Royale%20Inbuilt.pdf
Hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa. Cheers.
Aug 16, 2011 | Heating & Cooling
Is it possible to convert a rinnai avenger 25 from natural gas to lpg?
Yes it Should but you will want to check with manafactuer because it will need a conversion kit for lp gas. Natural gas is a different p.s.i. than lp gas so don't try without conversion kit. It should be just a small fitting that goes inside the gas valve. Hope this helps have a good day
Aug 12, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Royale IB35R ,the flame goes off once I released the press button, it wont hold on as usual
pamgee - it may be a case of not holding the ignition button in long enough ( at least 15 seconds) so that the flame failure device (Thermocouple) will get hot enough, to maintain the pilot flame and the low burner. If it fails to light and hold the first time, push the igniter button again and release it. Wait 30 seconds and try lighting it again.
In case you have misplaced the Owner's Manual, I have provided a link that you can download & print for future reference. http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Flames/Royale%20Inbuilt.pdf
I hope this helped you to solve the problem ... Cheers
Jul 12, 2011 | Heating & Cooling
I have a rinnai LPG 6 burner gas heater, it starts fine but wont ignite the middle left burner. It has a blue flame over the top that occasionally radiates down the burner. All the other 5 burners work...
sounds like the injector hole is too largefor that burner have you had it converted reciently
lpg injectors are only half the size hole of natural gas injector, could have a blockage in the injector diverting the gas flow
Jun 09, 2011 | Rinnai Heating & Cooling
TRIDENT LPG EXCEL GAS FIRE PILOT FLAME VERY POOR AND WILL NOT RUN CONSTATLY have blown jet out etc
Hi, This needs new pilot assembly,when the fire uses lpg they have a harder time of it than with natural gas.They burn hotter and lpg is less forgiving .Let know if you need help further or parts. Will
Aug 27, 2010 | Heating & Cooling
Hi I have a rinnai flame fire royal model ib35etr It keeps going out and flashes number 12 on the screen we are moving and packed the book
I had this same problem last year and went through all the checklist in poshpoms suggestions ( I am on mains Gas ). The issue was caused by the Flame rods. Near the 2 pilots at the front and the back. Those small rods each that 'senses' the flame become inadequate, so they were replaced with a new pilot assembly from Rinnai that had longer rods and better coverage. Issue was fixed. Good Luck.
Aug 23, 2010 | Heating & Cooling
Does not want to start
Jul 21, 2010 | Rinnai Heating & Cooling
What is required to convert an LPG Rinnai 1001 to natural gas
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
Jun 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I want to convert to propane. Rinnai dont carry kkts for these anymore . . . . are there any way to convert these?
i want to convert one to natural gas from LPG would u like to swap the pilot assy and jets i cant find a conversian kit anywhere...
Apr 23, 2009 | Kitchen Ranges
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
