Wharfedale IS73 - Sound keeps cutting out
Hi. I have a wharfedale IS73. The sound keeps cutting off after about 5 minutes whether it's on radio or cd. Makes a noise as though it is switching it's self off and keeps doing it. I've turned it off overnight but not is still the same. Any ideas if this is repairable? Thanks
SOURCE: Clicking sound in tape deck
All Aiwas  are prone to this problem.  The doors are a real pain and easily give up the ghost.  I have 2, both probmatic in this direction.
I have spoken to others about this problem. Seems no easy fix.
Have you in your case, tried leaving and old tape in the tape part of your  unit . The noise you hear, usually starts when tape unit area doors are about to pack a wobbly. Unless under warrenty, proberly,
not worth getting fixed.    It seems something gets weak in the activation part and get a mind of its own.  Very common after about 3 yrs of ownership.  All the best: jamz
Posted on Oct 25, 2007
cygnet
  • 3 Answers
SOURCE: Wharfedale dvdrhd400 problems
posted by msladsy on Dec 21, 2007
Report abuse
When the initial set up ran for the DVD recorder it set the correct time and, I assume, the correct date.
However, I had problems with the display and went through various settings until I solved the display problem.
Unfortunately, during the process, which included disconnecting the power, the clock was reset, starting at midnight and 1st January. There appears to be no way to access the clock.
How do I get the recorder to display the correct date/time?
Mark
Comment by msladsy, posted on Dec 21, 2007
This solution may work for other Wharfedale DVD recorders as well as the DVDRHD400F.
Use your Setup button to acces the 'Setup' menu.
Choose the 'Preferences' menu.
Choose 'Factory Defaults' and click on 'OK'.
The recorder will restore the factory defaults and the first screen it takes you too is the 'Initial Setup' screen where it asks you to enter the correct date and time.
Mark
Comment by msladsy, posted on Dec 22, 2007
May work on similar dvd recorders. Would help if Wharfedale included this in their users manual.
Posted on Jan 28, 2008
jango2
  • 38 Answers
SOURCE: Speakers are making a crackling sound then cut out.
Sounds like an internal loose connection somewhere, possibly anywhere, a connector on a pcb, a dry solder, loose pin on an IC. Tough for an end user to solve this, would entail opening the unit and investigating. I checked the rear panel in the op manual and this model has no ribbon connectors else i'd have asked you to check them.
Posted on May 20, 2008
MJS_1
  • 150 Answers
SOURCE: Sony Dream Machine clock radio
0) Read the last answer first :) it is the most likely.
1) Make sure that the noise is electronic, not mechanical,
a) Electronic noise comes from the speaker
b) Mechanical nose originates in the clock
(older mechanical clocks only)
c) Clocks come in 3 varieties:
Electronic
Mechanical "Flip Leaf"
Mechanical "Motor/ Gear" driven.
2) Assuming that your clock is electronic, there are
only two possibilities for causing static.
a) Extremely intense electromagnetic interference,
as in radio waves, from a thunderstorm or a powerful
transmitter nearby, such as a HAM radio or even
an active cell phone.
Intense electro-magnetic waves can be picked up by
internal wires within the radio which act as an antenna,
rectified (demodulated) by internal diodes and transistors,
filtered by internal capacitors and the speaker's inertia,
and still present enough audio frequency energy to the
sensitive speaker coil to be "quite" audible and irritating.
This can happen even with the power off, when the
interference is so strong that it needs no amplification !
This happens to my computer speakers, every time my
cell phone rings, and starts transmitting a return signal.
3) The power switch is intermittently shorting causing a small
amount of DC power to enter the radio, the more intermittent
the switch, the more noisy it gets.
This causes my old clock radio to turn on by itself when its
not supposed to.
The cause of the problem in either in the main power/ mode
switch, or in the clock driven switch or relay.
4) Old switches and volume controls get oxidized with time
and/or bridged by products of corrosion. The simple solution
is to clean them using a good aerosol contact cleaner,
available from an electronic shop for about 10 bucks.
Simply spray the cleaner into all the switches and controls,
while vigorously exercising each switch or control back and forth.
Make sure that you use a safe "electronic cleaner" designed
for the job. It must be safe on plastics, non-conductive, good
solvent and it must evaporate quickly. Don't breath the stuff !!!
Typically the spray will contain TF (tri-fluoro-ethane), or some
other freon substitute.
Freon (Di-fluoro-di-chloro methane) is bad for the ionosphere,
now illegal in most countries for that reason.
Also stay away from Carbon-Tetra-Chloride, which is
VERY toxic.
Do NOT improvise, or use acetone or alcohols, which may (will)
melt the plastic, causing the controls to permanently seize.
Get electronic contact cleaner from an electronics hobby shop.
Good luck. Martin
Please rate my answers.
Posted on Jul 12, 2008
mohammed387
  • 1952 Answers
SOURCE: Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Posted on Oct 31, 2008
Wharfedale ipod & subwoofer
Your hi-fi is not part of a hard drive or a shuttle computer. If you have a problem with your Hi-Fi, it would be best to tell us the make and model and ask in the Hi-Fi or stereo section.
Jul 12, 2013 | Shuttle MediaDock IS73/320 LVD...
My wharfedale sw150 subwoofer cuts out in normal viewing, any suggestions
If your Wharfedale sub is powered, it gets its input from a subwoofer output on the rear of the Sony. At a certain level, your sub is turned on and sounds just fine until the level decreases during quiet passages of music then it turns off. I believe the theory is that this approach prevents start-up "pops" but in practice it is a poor solution. I have had several subs that have acted this way. I don't know of a way to fix this short of eliminating the level-controlled turn-on circuit
Sep 28, 2012 | Wharfedale SW150 Subwoofer
The cable that connects the subwoofer to the main unit on my Wharfedale IS73 ipod docking station is broken ... where can I get another one ?
You can get your wire from a shop which sells mobile accessories or sound accessories.
try asking them for 3.5mm audio jack.
this will not cost more the rs.50 or $1.
or just take your damaged wire to those mentioned shop and ask for the new one!
best of luck!
regards!
Jul 21, 2011 | Audio Players & Recorders
Hi i" ve bought on
This may help. If it's not the exact model you have it will at least get you started as subwoofers are pretty much teh same for connection and operation.
http://www.wharfedale.co.uk/Portals/0/PDF_Data/Manual/DIAMOND9_range.pdf
Others here...
http://www.wharfedale.co.uk/Support/Download/Manuals/tabid/71/Default.aspx
May 06, 2011 | Wharfedale SW150 Subwoofer
Hi I have a wharfedale is73 ipod docking micro system and I cannot get my ipod classic to work on it. I have tried a different ipod on it and it works fine.
Unfortunately, there are many ipod docks that are not compatible with the full range of ipod generations. Usually the case is that on older docks newer ipods dont work and vice versa.
Hopefully this helps
Jan 07, 2011 | Audio Players & Recorders
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
User manual
try safemanuals.com or elitezoom.com
May 31, 2009 | Wharfedale Diamond 8.3 Main / Stereo...
Cable has broken for Wharfedale IS73 iPod Dock Micro, where can i find another one??
i have got a warfendale is73 system, my ipod dock is missing, where can i obtain anothet one please
Apr 22, 2009 | Audio Players & Recorders
99 people viewed this question
 Grubhead
Grubhead
