Question about Proscan 26LB30QD 26 in. LCD HDTV
Proscan tv surround sound hook up
I just got a Proscan LCD TV and i also got a Durabrand DVD home theater system combo (surround sound/ DVD player). the DVD player plays movies and the picture shows up fine on my tv and the sound comes out of the speakers on the surround sound. but my question is how to get the sound from my cable channels on my tv to play on the surround sound speakers.??
  • 2 more comments
  • wrightkodi Jan 28, 2009
    you would think so, but here is the problem. it does not say audio out on the back of the tv. i had the red and white cords into the surround sound box plugged into the the audio in and tried every plug in in the back of the tv.??
  • Anonymous Feb 01, 2009
    same problem cant connect my surround sound to play with my chanels
  • Anonymous Mar 23, 2014
    Proscan Tv/dvd combo pldv321300
  • Anonymous Mar 25, 2014
    Tv/DVD combo, trying to hook up external DVD player. I get sound but no picture.
  • 4 Answers
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
  • mjdoyle Jan 28, 2009
    Looking into this model further it seems that it only outputs audio via
    coaxial. what this means is that it will output through an orange RCA
    connector. Your surround must have a coaxial audio input to use this.
    I am not sure if the audio over this digital interface is for the DVD
    only or if it will also upconvert your cable.
    Try hooking an RCA cable from the orange output to an orange input on your Receiver.
    Another option would be to buy a cheap VCR and feed your cable into
    that and use the audio output of that into your surround. You would
    then use the VCR to change channels as well
    New Friend:
I connected the orange cable to my tv to the receiver
Posted on Nov 08, 2014
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
Proscan 37 inch LCD 37LB30Q Model
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
Jul 08, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Can a durabrand dvd home theater system,model #sts96 be used on tv for surround system
I have a sts92 system and run the tv sound through it for surround sound. My Tv has an AV out option, so I ran component cable from the AV out on the TV to the AV in on the sts92. When watching TV, turn on the theater system and set the function to AV in.
Feb 24, 2009 | Durabrand STS92 System
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Need home theater hooked to TV with built in DVD
This is the easiest way 2 explain it. Hook up on the home theater should be labeled in and out. same as on the tv. The TV might no have that feature as the DVD is built in. You might just have an option for sound from the TV/DVD to the home theater. Again OUT from TV IN to receiver. Same with any other device set up.
Jan 27, 2009 | Durabrand 5.1 Surround Sound Computer...
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Dvd hook up
how do i hook up my dvd player to my proscan tv
Apr 12, 2008 | Proscan 26LA30Q 26 in. LCD Television
Proscan 32LA30Q & Surround sound
Make sure that your patch cables are cumming from the audio line OUT of the TV to the audio line IN on the surround amp. A common mistake on hook up is usually the problem.
Jan 14, 2008 | Proscan 32LA30Q Television
Proscan 26LB30QD 26 in. LCD HDTV Logo
2,807 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
