Question about Polaroid i835 Digital Camera
Cannot get new camera to install memory on sd card
It is a sd card from my other digital camera.do i need to purchase a new one
  • 4 Answers
No, it should work fine with the new one. If it's not working, make sure the card isn't locked. If its still not working, make sure the card isn't full and if that doesn't solve it, I would advise to get a new card.
Posted on Feb 03, 2009
5 Suggested Answers
pontelemon
  • 538 Answers
SOURCE: new sd memory card doesn't work in my digital camera
It will not work with any "sdhc"
Posted on Mar 19, 2009
  • 11967 Answers
SOURCE: ennyah tech digital camera
You need to format the card in the camera.
Posted on Sep 07, 2009
Tri3mast
  • 747 Answers
SOURCE: Just purchased and installed SD
A bunch of stuff could be happening. First did you format the new card if not see if it can be formatted to the camera. if not then you will need to download the newest updates for that camera from the Kodak web site. For example the camera is set )internally) to accept a 1gig card and you installed a 2gig card it won't recognize the card until the camera firmware is updated. The easiest way is to format the card first.
Posted on Dec 24, 2010
  • 66 Answers
SOURCE: I have a Samsung S730 digital camera and like it
Hi
The Samsung S730 digital camera will work with 2Gb Secure Digital (SD) cards without an issue. If you want to go with a higher capacity card you can also use 4Gb and 8Gb SDHC cards.
Hope this helps
David
Posted on Dec 29, 2010
WHERE CAN I FIND A SD MEMORY CARD,NOTSDHC
Yes, SD memory cards can still be purchased.
May 21, 2014 | Nikon Coolpix L110 Digital Camera
How do i transfer files from my cobra digital mini 150 to a pc?
Yes purchase an USB micro SD card reader.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 09, 2012 | Cobra Digital Mini 150 5.0 Megapixel Mini...
My hp officejet 7210 all in one will not read my SDHC memory card for my new Panasonic camera. Why? Should I purchase just a SD memory card? Will that work?? Thanks
Purchasing an SD card might be better. Just for the fact that when your printer was manufactured the technology for SDHC cards were still not incorporated in your printer.
Feb 06, 2011 | HP Office Equipment & Supplies
This is a new purchase, never been used. I inserted the card, installed the batteries and then pressed the putton to turn it on but the display on the screen says "Memory Full! Please Insert an SD...
You didn't specify the make and model of your camera, but from what you do say I suspect it uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible. Try using an SD card 2GB or smaller.
Jan 03, 2011 | Cameras
Purchased new memory card for my canon powershot A520 and I keep getting a "memory card error". I've purchased two different cards and get the same error message. Original card that came with...
From page 145 of the A520 user manual, it appears that the largest SD memory card that this camera is able to use is a 512MB SD memory card. The manual is dated "2004", so this size limitation is not unusual for a camera of this era.
If you've purchased anything larger, there is a good chance that it won't work with this model camera.
Dec 30, 2010 | Canon PowerShot A520 Digital Camera
Just purchased and installed SD memory card and the camera says memory card is unusable (Insert new memory card)
Dec 17, 2010 | Kodak EasyShare Z710 Digital Camera
Camera is stating No Card when there is an SD card in camera
camera sd card board is faulty you need to relace new sd card board.
Jul 09, 2010 | Canon EOS Rebel XSi Digital Camera
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
New memory card and the camera says its full
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
New memory card says memory card full
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
Jul 29, 2008 | Kodak EasyShare C330 Digital Camera
Polaroid i835 Digital Camera Logo
55 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
