Question about Smeg DWI614 Built-in Dishwasher
How to remove bottom panel on my smeg dishwasher
Smeg Dishwasher Humming Noise
Hi olsworth,
I think you may have something hung up in the pump.  This is a bad situation.  See if you can remove the dish baskets, and remove the strainer cover in the bottom of the chamber and see if something is in the pump drain area. I am not real familiar with the Smeg, But I do know that humming is related to the pump motor in a strain. I will study this more and get back with you soon.  Please do not vote yet.  I am wanting to get this solved for you, and it may take a bit of study on my part to get you an answer.  Please give some feedback in to what you are finding on your end.
Oct 16, 2007 | Smeg DWI614 Built-in Dishwasher
Smeg dishwasher problems
Check the screen, which is under the bottom wash bar. You need to pull out and clean and then see if it will drain. Also listen to make sure the drain motor is running, it also could go bad on you.
Aug 25, 2014 | Smeg Dishwashers
Hi can any body tell me whats wrong with my smeg dishwasher it only has program lights which now do not come on at all a part from the power light which beeps/but after that nothing
Probably computer is corrupt. Go to your circuit breaker panel and remove power from the dishwasher for a full minute. THEN< POWER back on. That should reset the computer.....
Jan 05, 2012 | Smeg 24 in. DWF614SS Stainless Steel...
Door wont close
Is the bottom rack in backwards?
Jan 01, 2009 | Smeg 24 in. STX2 Built-in Dishwasher
E2 error in smeg dishwasher
your english sounds fine to me - far better than my bulgarian!
literally - in the front of the machine down at the bottom there is a panel about 10 cm high which can be unscrewed to give access to the base of the machine
tresilla
Nov 22, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Nov 20, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Jun 01, 2006 | Smeg 18 in. DWF410SS Slim-Line...
Smeg DWI614 Built-in Dishwasher Logo
113 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
