Question about Microsoft Xbox 360 Console
360 says unplayable disk
I have tried several disk and have eliminated the possibility that it is the disk itself. I have gone through the procedure of removing the hard drive with no success. I do not hear the sound of the disk rotating.
  • mmikemccormi Mar 05, 2009
    I had my hard drive changed and it fixed the unplayable disk problem. However, after getting my console back from the repair shop the green light on the console doesn't work and the controllers do not have any affect.
    Scholar:
  • 35 Answers
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Posted on Mar 07, 2009
  • 60 Answers
YOU PROBABLY HAVE A BAD DISC DRIVE OR THERE IS A SHORT POWERING THE DISC DRIVE
Posted on Jan 28, 2009
Disk unreadable but clean disk not scratached
http://www.youtube.com/watch?v=iOmNtrStDgM
Turned on your Xbox 360 console one day and and when you try to play your game you got the message "This disc is unreadable" OR "Unplayable disc".....??
First determine whether it's a fault with the disc or not, by having a look on the disc itself & make sure it's not scratched and there are no flaws even on it, and try other game discs on your Xbox 360 console .
If your disc is scratched or have flaws try putting other discs in your Xbox 360 console just to make sure it's the disc not the actual console causing the error, If other disc are working fine, refer to the scratched discs page on our website to know what are the steps you have to follow to get it sorted out.
If the disc is not scratched and doesn't have any flaws on it, cleaning the disc and trying it once more may solve the issue, if that doesn't work try to check it by putting other discs in your Xbox 360 console, if they all work that would be definitely a fault with the disc itself and in a case like this you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "This disc is unreadable" OR "Unplayable disc" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Jan 03, 2010 | Microsoft Xbox Console
Same thing but with noise
This is more than likely your laser that is dead or dying and its possibly a samsung or hitatchi drive, be
careful when buying a new laser because there is a lot of dodgy ones around at the minute which can damage
your machine or at the very least will be inferior and not last long.
It could also be the logic board or the drive belt too, if the logic board is faulty no matter how many lasers
you try it will do the same, the fix is to replace the logic board.
if its the drive belt well this is very easy to try and is what id try first, open your 360 tray and look
inside the 360 you should be able to see the drive belt, make sure its attached properly and then take this
out. replace it with a new one and see if this recifies your problems.
SOMETIMES if a drive belt is stretched it will not close properly and then a fault like yours will occur. its
all a matter of eliminations. Drive belts can be found on ebay.
Linda.
www.XboxRepairKit.co.uk
Sep 06, 2009 | Microsoft Xbox 360 Console
Xbox console reads disks then says unplayable disk
this is the laser unit that is faulty, it either needs replacing or you could try cleaning it with a cotton earbud to see if that helps. if its still doing the same after cleaning you could also try adjusting the laser power, sometimes after its been played for years the laser loses power and you will have faults such as this. adjusting the 'pots' on the laser itself to around 282 will help greatly.
if you need a guide just email me or let me know via my website at www.fixmyconsole.co.uk and i will be more than glad to help you.
regards
Feb 06, 2009 | Microsoft Xbox 360 Console
Games will work sometimes but mostly comes up unplayable disk
Sounds obviouse but have u tried just running a laser cleaning disk? always start simple :)
Nov 14, 2008 | Microsoft Xbox 360 Console
Unplayable disc error on xbox 360.
goto youtube and search for unplayable disk error fix.
Jul 12, 2008 | Video Game Consoles & Games
How?
the drive is going bad. or gone bad. might be time for a replacement
Jun 05, 2008 | Microsoft Xbox 360 Console
ALL disks I put into my 360 are reading,"Unplayable disk". I even tried...
your cd unit is gone, there is no way you can fix it without opening the console.
May 25, 2008 | Microsoft Xbox 360 Console
Xbox 360 unplayable disks
What you have to do, is clean the "eye" the thing under the disk tray that reads the game, you probabley got that dirty or damaged somehow. Try spraying compressed air into the open disk tray to get any quick dust off. if that does not work then try finding other ways to clean it or call 1-800-4my-xbox and have microsoft check out the system to see whats wrong with it
Jan 15, 2008 | Microsoft Xbox 360 Console
Unplayable disk error and sometimes noisy
Go to Youtube and look up opening XBOX 360. There are lots of videos and tutorials explaining how to open up your XBOX. JUST REMEBER TO KEEP THE SILVER STICKER INTACT SO YOU CAN PUT IT BACK AND NOT VOID YOUR WARRANTY
Oct 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
