My sister in law just purchased a new ge washer model # WJSR4160G2WW AND INSIDE THE FRONT PANEL YOU CAN SEE A GREEN FLASHING LIGHT ...WHAT IS THIS SHE IS WORRIED SOMETHING IS WRONG WITH THE WASHER
  • 15,935 Answers
This is simply a visual of the timer counting down.
No worries.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Display doesn't light up
Check the power cord is tight. and check that you have 220 volts then contact me back
Jan 20, 2014 | GE Profile Harmony DPGT750EC Electric...
Ge washer gtwn3000mows doesnt get water spin or rinse
Remove the front panel. The motor will have a green light flashing error codes. Count the flash sequence and post it back.
Nov 22, 2012 | Washing Machines
Does not work fills with water and just sits
Remove the front panel. The motor has a green light on it that will be flashing an error code. What is that code?
Nov 16, 2012 | GE Profile WPRE6100G Top Load Washer
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
Aug 31, 2009 | Washing Machines
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
