Question about Acer Aspire 7720 Notebook
Os xp cant read the hard disk
Scds
  • Vincent  dela cruz
    Vincent dela cruz May 11, 2010
    go to system setup and check if your computer detect your hard drive..
Run only win 98.get's blue screen when trying to install win xp,vista on win7
you get this message when there is some hardware which is incompatible or fails / crashes during the installation of OS since you have tried a different hard disk already it cannot be that so try with a different Ram or update bios / replace motherboard.
Feb 10, 2012 | Abit Computers & Internet
Bios cant read a 500GB HD
p4vm800 fsb mb solution- format hard disk in another compter and install window (os) on your hard disk .
connect with your motherboard ,turn on computer press bios entering key ( f2 or del ) . after entering the bios set up set as defalt . install window (os).
Aug 18, 2011 | Asrock P4VM800 Motherboard
It wont boot, but read corectly at bios screen, but when i try to reinstall an OS such as linux ubuntu, win xp and win 7, it says that cant find any HDD..@ linux Os, its readable but when we try to format...
I would recommend using a boot disk and run chkdsk (windows boot disk) or fsck (linux) This will help fix bad sectors if you use the correct options. USe the "/?" in windows for help and "man fsck" in linux.
Good luck and let me know how it goes.
Joe
Feb 15, 2011 | Fujitsu - MJA2160BH 160 GB SATA Hard Drive
Hi I have a Fujitsu Mobile MHV2120BH 120 GB SATA Hard Drive, I want to install XP home on it. But Ive been reading that I need Sata/raid drivers for the computer to see the drive. I have a HP Pavilion...
The SATA drivers will be on the XP disk. Just put the XP disk in your CD drive, partition the new disk and load the OS.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 16, 2010 | Fujitsu Mobile MHV2120BH 120 GB SATA Hard...
Xp install disk cant find any hard drives on my hp pavillion dv 5000. it was given to me without any install disks
You will have to delete the partitions of the hard drive before using the xp disk because if there is any partitions formatted as EXT (non dos) the xp disk will not read them. You can download a dos disk of the internet to do this. Once you have used the fdisk command which you can use to re-partition your hdd you should be able to install xp no problem.
Jan 22, 2010 | Computers & Internet
Fans and disk drives power up, but hard drive will not.
check connection from hard drive to moherboard make sure all is fitted well and run OS set up..it will not continue installing OS... if hard drive cant be read..,,if OS will continue with set up..then ur hard drive is now working...
Oct 07, 2009 | Compaq Computers & Internet
CANT BOOT FOR REINSTALLATION OF XP, IT SEZ "NTLDR" IS MISSING, ALSO MENTIONS SOMETHING ABOUT THE HARD DRIVE NOT WORKING
If you have the OS disks try a repair first. Run the OS disk and choose the repair option rather than reformatting. That usually fixes ntldr issues.
Apr 30, 2009 | Computers & Internet
No boot disk error when hard drive disconnected
Are you making the disk the "master" device when you plug it in to the PC?
Nov 02, 2008 | Computers & Internet
Acer Aspire 7720 Notebook Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
