The instruction at ''0x009d5d79''referrenced memory at ''0x00000000''the memory could not be read
The instruction at ''0x009d5d79''referrenced memory at ''0x00000000''the memory could not be read how to solve this please help
    Problem Solver:
  • 12 Answers
A similar problem was present on a recent repair, and the issue was not a memory module, but a defective electrolytic capacitor on the motherboard. Those capacitors are easy to spot, as they show some bulging on top of them and may display some brownish buildup. The capacitors will be marked for 10 volts or so and about 1000 microfarads. look nearby the memory modules. Replacement is relatively easy, but tshould be performed by someone familiar with electronics. HDalacarte.com guy.
Posted on Jan 23, 2013
HP Scanjet 3300C I donot seemto beable to scan with the above. Whenever I select "Start New scan " I get the following " an undefined error has occurred (2117). When I close the programme...
  1. Unplug printer from usb
  2. remove printer from installed printers in windows, chose delete all files when asked.
  3. Reinstall printer software from disk
  4. connect printer back to computer usb
Jul 24, 2008 | HP Office Equipment & Supplies
I have a Asus x53e. Whenever I try to download a document ( PDF or JPEG ) to gmail compase messages I get a popup window that says: application error, The instruction at 0x63ea75f7 refinced memory at...
It would be nice to be able to boot it up on a Live CD and see if it's reliable then. It's hard to tell if this is a hardware or software problem.
Oct 29, 2013 | ASUS Computers & Internet
The instruction "0x7c911689"referenced memory at "0x00000000". The memory could not be "read". click ok to terminate. Cancel to debug. ...
hi stevemineer,
in internet explorer>Tool> internet option> Advance Tab> under security uncheck Enable memory protection to help mitigate online attacks
Hope this helps
thx
Banaple
Sep 02, 2010 | Computers & Internet
My Ultra (Serv No. 106611410) is getting slower and slower. Two things: (1) I keep getting the following pop up window - HPZipm12.exe Application error - which reads "The instruction at ")x7c910a19"...
please restart ur computer then try to go to safe mode and check there if still not working open the tower and plug out all the devices connected inside open and replug all the devices like hard drive and ram slots clean the ram slots please xcheck the fans if they are working properly
Nov 20, 2009 | Ultra Computers & Internet
My computer with Windows XP Pro SP2 is crashing often, after i had connected a hdd with my computer ============ CPU-Z TXT Report Processors...
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/hdd..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Nov 13, 2009 | Asrock K8NF4G-SATA2 Motherboard
I can't shut my notebook off
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | HP Compaq nx9010
When i try to burn a dvd in adobe encore cs3 i get this problem The instruction at “0x007fa94c” referenced memory at “0x00000000”. The memory could not be “read” Click on OK to...
Probably you are with problem with your RAM memory. Replace it, or , if you have more than one memory card, remove one by one till you find what is damaged.
May 02, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
