Question about GPS
Remote car starter starts vehicle but vehicle shuts off right after
I had an aftermarket remote stater put in my 2003 chevy astro van in 2003. It worked fine for a year or so then started giving me problems big time! It hasn't worked right for several years now. It turns the engine over and engine runs for a few seconds and then shuts off right away. Is it a security issue or what?? Had it fixed twice but guy is out of business now and no others are interested in fixing old remote starter so I have a friend who's willing to give it a try. Any suggestions? Thanks!
  • 154 Answers
You have "lived" with for 14 years now so why are u trying to fix it now?????????
anyway find where remote starter's relays are under dash test the relays... one of them is broken or not wired right.
Posted on May 15, 2017
  • 86 Answers
SOURCE: Temperature below safe level
I've fixed that error by swapping out the PCB board (or the keypad board). Which you can't very easily do that.. unless of course you have a boneyard of these lying around. Additionally, it could be the Hard Drive, this error hasn't been narrowed down to any one specific cause to my knowledge. I'll take it off your hands if your going to buy another one though. Respectfully, -Dan
Posted on Oct 24, 2006
  • 504 Answers
SOURCE: GPS not working
You can try the reset button, but it sounds like you may have a dead battery. When you plug the unit into the car, what happens? What if you plug it into the computer? The reset is under the faceplate. Put your finger under the indentation on the top of the faceplate, and pry it off. The reset button is on the right side of the unit. Let me know what happens.
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: Battery
need new batteries.
Posted on Oct 21, 2008
SOURCE: My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Posted on Oct 01, 2009
SOURCE: Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Posted on Nov 19, 2009
Astro start remote car starter cranks engine over but will not start 2003 F150
Disconnect Astro battery and battery in remote. Leave that way 10 minutes, reconnect Astro first.
Oct 30, 2017 | Cars & Trucks
My remote starter for 2008 sebring starts but shuts off in about 10 sec
Is this an aftermarket remote starter? Is this a new install or has this unit worked in the past? It sounds suspiciously like the vehicle immobilizer system is shutting down the vehicle since it knows that the key is not in the ignition. Most aftermarket kits require "bypass module" to fool the immobilizer during the remote start running period. These can fail or reset and this can cause the symptoms you are having. If it is a factory remote starter, I'm at a loss unless theirs has a similar configuration and this can have the same issues.
Mar 13, 2015 | 2008 Chrysler Sebring
Frozen gas lines in 2003 Chevy Astro van
Replace thermostat in the motor ,make sure the hoses to the convertor are not blocked ,pour hot water on the fuel pipe and convertor to thaw out.
Mar 01, 2014 | 2003 Chevy Astro - Passenger van, with...
I have an astro start remote 4204/5204 in a 2004 GMC Sierra, when trying to start the vehicle, its starts then immediately stops then starts to crank over motor but does not start...
I don't have a solution, but I have a variation of this problem... My remote start will start the vehicle (2004 GMC Yukon) then shut it right back off after less than 1 second. But, ONLY when it's cold. Once the truck warms up, the remote start works fine. The "start fail" code says "Engine over revving"... Which is odd, because the engine idles the same cold or warm - around 1100 to 1400 at start, then down to about 800 after just a few seconds. Par for the course for me - no one has ever seen this problem before. I was told by a friend not to install an aftermarket remote start on a GMC Yukon, as they are nothing but trouble, but I didn't listen.
Nov 19, 2013 | Vehicle Parts & Accessories
Remote start works but shuts off right away
When you say right is as soon as the vehicle starts....or is it 10-15-30 seconds later? Is this a factory remote start? If not, and you installed an aftermarket one, what is probably occurring is that your factory anti-theft system is seeing the vehicle running without the key in the ignition and activates the immobilizer which shuts down the vehicle. Aftermarket remote starts require adapter electronics to bypass the immobilizer until the operator enters the vehicle and inserts the key. This is why most aftermarket alarm systems are installed by trained pros.
Nov 05, 2013 | Dodge Grand Caravan Cars & Trucks
Bulldog remote start mazda tribute 2003
check out,go to the vehicle wiring diagrams.There they should list in the top if you need a 791 bypass for your vehicle.
please rate this if it was helpful to you.
Dec 29, 2009 | Bulldog Remote Starter & T-Harness Kit for...
I have a 2006 ford explorer i put a bulldog remote stater on it but cant get it to start ever thing comes on but the starter wont come on no crank
put the key in the ignition DON'T turn the key, now remote start the car, if it starts, you need a bypass modual, send me a message if you need one and I will let you now where to get the best price where you live
Dec 19, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Remote starter will not start engine
Internal relay is faulty - replace the brain.
Unfortinately - There is no user-fix
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 01, 2009 | Bulldog Remote Stater w/Keyless Entry and...
Can you override and start the 2002 chevy blazer without remote?
a factory keyless entry will not have an override but it does not disable starter.if you are have security issues it is problem with passlock system. if it is aftermarket alarm system then there is a button somewhere but varies where installer put it
Dec 10, 2008 | 2002 Chevrolet TrailBlazer
GPS Logo
42 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
