Question about Nordic Track A2155 Treadmill Walking Deck
Nordic Track A2155 talking about pushing red button
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
SOURCE: nordic track exp 1000. buttons don't work. LED's
Did you ever find out what was wrong? Mine is doing the same.
Posted on Apr 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
  • 3 Answers
SOURCE: i have a nordic track
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Posted on Oct 29, 2011
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
My nordic track 2000 lights come on but will not respond when pushing the buttons
adjust the reed switch, clean it , test for open or faulty, tight the connector very well, see the diagram attached, Replace batteries too
Jan 09, 2013 | Nordic Track Nordictrack Exp 2000...
I HAVE A NORDIC TRACK E 3500 WITH AN INCLINE PROBLEM WHERE BY IT DOSEN'T RESPOND TO THE REQUIRED LEVEL .I'VE TRIED TO RESET MANY TIMES WITH NO SUCCESS .IT SEEMS TO CHANGE THE ACTIONS ON...
1)Lube the shaft, gear from elevation motor see the picture
2) adjust the POT a little.
3) see the diagram attached.
4) RUN the software calibration go under the hood motor and see the instructions for troubleshooting, and fix it.
God bless you
Nov 11, 2012 | Nordic Track NordicTrack Professional...
I have a nordic Track EXP2000i that works for about a minute after it is plugged in but then the control console stops responding to buttons being pushed. The only buttons that beep are the 5 and 6...
hi,
check the other push buttons on the control console. if found faulty replace it. it is the only thing u can do in the control console. if problem remains u should replace the control console with a new one. for that u have to consult the manufacturer.
do one more thing before consulting manufacturers, remove the control console put out its circuit board. using a hair drayer heat the whole board. do not over heat.. then re fix it and test it.
ok
Dec 22, 2010 | Nordic Track Nordictrack Power Board...
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
I own a nordic track exp1000 series and only recently had trouble with it. The panel lights up when the key is inserted but will not start up when the start button is pushed. What do I need to do to...
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Jul 05, 2010 | Nordic Track NordicTrack T7 si Treadmill
I have a nordic track c2155. it powers up, but every button i push makes it beep. i have made sure the reed switch is 1/8th away from the pulley and that the unit has power
Aug 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track A2155 Treadmill Walking Deck Logo
53 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
