Question about KWorld 1680 TV BOX HIGH-RESOLUTION EXTERNAL LCD TV TUNER (Retail) (KW-TV1680R)
How to fix a out of range k world external tv box without its remote control
I have an emish tv box the remote switches it off and on if I press it after about 5 seconds. But if I switch it off with the remote i have to use switch on back of box to switch back on
DIRECTV - Support: Your Remote Control
www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
DIRECTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On ...
Program the remote for your TV - Fiber Help
support.google.com > ... > About the remote control
GoogleThe Google Fiber remote control is not designed to fully control external audio equipment. ... Press and hold the button on the original TV remote that you want to program on the Google Fiber remote. If the learning works, the TV power button on the Google Fiber remote blinks twice ...
Dec 26, 2015 | Televison & Video
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
Standard remote won't work away from tv
If you could not get range from the remote, try by replacing its battecies. Still there is no result, replace the infrared signal emittion diode [LED] at the remote control.
Dec 14, 2013 | LG 55 55LW5600 3D LCD TV
How to program a dtc remote to a world tv
Visit this link for details. It has all described about how to synchronise a remote control to a device.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
There are over 160 posts. Pull up the older posts. You can get details.
Apr 21, 2012 | Televison & Video
Resolution is out of range.. when i switch on the computer and tried to switch on tv card then " input no support " appears...how can i resolve this
Maybe the resolution you set on the tv tuner is higher than the monitor's resolution, thus the error in displaying the tv. After you turn on the tv tuner, try to change the resolution from the remote control several times, maybe you can find one that your monitor can handle. Good luck!
Dec 09, 2010 | KWorld 1680 TV BOX HIGH-RESOLUTION...
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Oct 21, 2010 | Televison & Video
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
I have an LG 37LC2D LCD TV that is locked.
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) are the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG 37LC7D 37 in. LCD HDTV
KWorld 1680 TV BOX HIGH-RESOLUTION EXTERNAL LCD TV TUNER (Retail) (KW-TV1680R) Logo
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Ruben Balisbis
Ruben Balisbis
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
